ObjectARX
looking for an example of using: AcDb3dSolid::createRevolvedSolid
1 REPLY 1
588 Views, 1 Reply
Hi read for a long time on the help files. Just don't get a clue how to start, by any chance somebody got a sample code of it. Much appreciate.
Gat
1 REPLY 1
Balaji_Ram
Hi Gat,
Here is a simplest example using createRevolvedSolid.
It creates a cylinder by revolving a line about the Z axis. Hope this provides you a starting point.
AcGePoint3d sp(10.0, 0.0, 0.0);
AcGePoint3d ep(10.0, 0.0, 10.0);
AcDbLine *pRevEnt = new AcDbLine(sp, ep);
Acad::ErrorStatus es;
AcDb3dSolid* pShapeSld = new AcDb3dSolid ();
AcDbRevolveOptions revolveOptions;
revolveOptions.setDraftAngle(0.0);
if((es = pShapeSld->createRevolvedSolid(
	pRevEnt,
	AcGePoint3d::kOrigin,
	AcGeVector3d::kZAxis,
	6.28318530718,
	0.0,
	revolveOptions
	)) != Acad::eOk)
	acutPrintf(L"\nSolid creation failed...\n");
	delete pShapeSld;
	return;
pShapeSld->setColorIndex(2);
AcDbObjectId id;
postToDb(pShapeSld, id);
Here is the postToDb method :
static Acad::ErrorStatus postToDb(AcDbEntity* ent, AcDbObjectId& objId)
	AcDbBlockTable*        pBlockTable;
	AcDbBlockTableRecord*  pSpaceRecord;
	if ((es = acdbHostApplicationServices()->workingDatabase()->
		   getSymbolTable(pBlockTable, AcDb::kForRead))
		   != Acad::eOk) {
		return es;
	if ((es = pBlockTable->getAt(ACDB_MODEL_SPACE,
								 pSpaceRecord,
								 AcDb::kForWrite)) != Acad::eOk) {
		return es;
	if ((es = pBlockTable->close()) != Acad::eOk) {
		return es;
	if ((es = pSpaceRecord->appendAcDbEntity(objId, ent)) != Acad::eOk) {
		return es;
	if ((es = pSpaceRecord->close()) != Acad::eOk) {
		return es;
	return ent->close();
Balaji
Developer Technical Services
Autodesk Developer Network
”Boost
