ObjectARX
Linker errors in ObjectARX 2013 related to AcRxClass methods.
4 REPLIES 4
sandeepk
1449 Views, 4 Replies
Here I am facing problem while building ObjectARX 2013 project which has be migrated from ObjectARX 2012 (It works well in 2012)
it gives errors like
1]
Error 9 error LNK2019: unresolved external symbol "__declspec(dllimport) public: bool __thiscall AcRxClass::isDerivedFrom(class AcRxClass const *)const " (__imp_?isDerivedFrom@AcRxClass@@QBE_NPBV1@@Z) referenced in function "public: bool __thiscall AcRxObject::isKindOf(class AcRxClass const *)const " (?isKindOf@AcRxObject@@QBE_NPBVAcRxClass@@@Z)
2]
Error 15 error LNK2001: unresolved external symbol "__declspec(dllimport) private: static void __stdcall AcHeapOperators::freeRawMem(void *)" (__imp_?freeRawMem@AcHeapOperators@@CGXPAX@Z)
3]
Error 18 error LNK2001: unresolved external symbol _acedSSFree
I think there is some mismatch related to iskindof() function call
sample code
AcDbEntity* pEntity=NULL;
Acad::ErrorStatus es = acdbOpenAcDbEntity(pEntity, EntId, AcDb::kForWrite, Adesk::kFalse)
if(pEntity->isKindOf(AcDbPolyline::desc()))
Any help will be greatly appreciated.
Thanks in advance.
4 REPLIES 4
It's look like missing include ac1st19.lib and accore.lib for linker.
Visual Teefy 2013 can help you: http://adndevblog.typepad.com/autocad/2012/04/migrating-objectarx-and-net-plug-ins-to-autocad-2013.h...
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Thanks for reply Alexander,
I can see ac1st19.lib and accore.lib files in folder c:\ObjectARX2013\lib-win32 which I have referenced in my project.
I think some sort of setting I am missing..
If your's code has line:
#include <arxHeaders.h>
then all the necessary libraries will be linking (using the directive #pragma comment (lib, "<lib-name>"))
It is not enough reference folder with lib's, but you have to add those lib's in Linker->Input->Additional Dependencies property of project.
Expert Elite Member
Thanks a lot Alexander.. It worked perfectly :):)
”Boost
