ObjectARX
Valued Contributor
2 Kudos
Post 1 of 13
Linker Error
3204 Views, 12 Replies
04-15-2012 07:02 AM
I'm converting from VS2008/Acad 2010 to VS2010/Acad2013 and I think I have most of my settings correct but I'm getting the following error which I don't understand:
Error 1 error C1900: Il mismatch between 'P1' version '20081201' and 'P2' version '20080116' C:\MVS.2010.For.2013\EMD_2013(32-64)\EMD13_Acad\LINK
"C:\MVS.2010.For.2013\EMD_2013(32-64)" is the path to my projects.  "EMD13_Acad is the project on which I'm working.
Any help would be appreciated.
Ed
Distinguished Mentor
100 Kudos
Post 2 of 13
Re: Linker Error
04-15-2012 09:41 AM in reply to: EMD1954
Did you Rebuild All?
Owen Wengerd
ManuSoft
Valued Contributor
2 Kudos
Post 3 of 13
Re: Linker Error
04-15-2012 12:00 PM in reply to: EMD1954
Yes, I'm doing batch rebuild (Win32 and x64).  I have 2 library files which I placed on the correct path and they are found when I rebuild the project file but now I'm getting an error saying that it "cannot open file 'mfc100u.lib'.  It's in C\Program Files\Microsoft Visual Studio 10.0\VC\atlmfc\lib" and my library path is:
$(VCInstallDir)lib
$(VCInstallDir)atlmfc\lib
$(WindowsSdkDir)lib
$(FrameworkSDKDir)lib
I'm also getting:
Warning 19 warning LNK4229: invalid directive '/FAILIFMISMATCH:_MSC_VER=1600' encountered; ignored C:\MVS.2010.For.2013\EMD_2013(32-64)\EMD13_Acad\EMD13_Common_Dict(32).lib(_Dict_Last.obj).
---and---
Warning 20 warning LNK4229: invalid directive '/FAILIFMISMATCH:_ITERATOR_DEBUG_LEVEL=0' encountered; ignored C:\MVS.2010.For.2013\EMD_2013(32-64)\EMD13_Acad\EMD13_Common_Dict(32).lib(_Dict_Last.obj)
"EMD13_Common_Dict(32).lib" is my library file when compiling for Win32.  I get the same warning with my file for x64 "EMD13_Common_Dict(64).lib"
I think my basic settings for the library files (Win32 Project with "static library", "precompiled headers" and "add common header files for mfc") are correct - they compile without any errors or warnings but I must have something wrong in the settings for the project files.
Finally, I didn't try to migrate from VS2008.  I created new projects from VS2010 and just added my .cpp and .h files into them.
Thanks again,
Ed
100 Kudos
Post 4 of 13
Re: Linker Error
04-15-2012 01:39 PM in reply to: EMD1954
You may have other problems, but it sounds like your library files are built with a different version of the linker than the one you're using now.
Owen Wengerd
ManuSoft
Valued Contributor
2 Kudos
Post 5 of 13
Re: Linker Error
04-15-2012 04:54 PM in reply to: EMD1954
I've deleted everything and started from scratch.  I set my properties as follows:
For both the libraries and the project:
Configuration Properties / General / Whole Program Optimization / Use LTCG
C / C++ / Optimization / Whole Program Optimization / Yes
Librarian / General / LTCH / Yes
For the project:
And in the project Linker / General / Enable Incremental Linking / No
Linker / Optimization / Link Time Code Generation / Use LTCG
Now I've got it down to:  "Error 3 error C1047: The object or library file 'Win32\3DFaceGrid.obj' was created with an older compiler than other objects; rebuild old objects and libraries C:\MVS.2010.For.2013\EMD_2013(32-64)\EMD13_Acad\LINK"
I don't know how my file 3DFaceGrid.cpp compiled to 3DFaceGrid.obj with an "older compiler" because I did a rebuild all and everything recompiled.
I get the same errors in x64.  Is there somewhere I can find how to set all of my configuration properties?
Any ideas?
Ed
100 Kudos
Post 6 of 13
Re: Linker Error
04-15-2012 05:24 PM in reply to: EMD1954
Make sure you're not starting Visual Studio with /useenv or some other obscure mode. Verify that your platform toolset setting is correct in each project. Have you installed any add-ons? Have you rebooted?
Owen Wengerd
ManuSoft
Valued Contributor
2 Kudos
Post 7 of 13
Re: Linker Error
04-15-2012 06:09 PM in reply to: EMD1954
Owen,
I shut down and restarted.
I deleted all of my output subdirectories.
I rebuilt everything.
Same error message.
My VC2010 shortcut is:  "C:\Program Files\Microsoft Visual Studio 10.0\Common7\IDE\devenv.exe"
My only add-on is the ObjectARX wizard 2012
I checked my $(IncludePath) macro for the library files and it has "C:\Program Files\Microsoft Visual Studio 10.0\VC\include".
I checked my $(IncludePath) macro for the project and it has "C:\Program Files\Microsoft Visual Studio 9.0\VC\include"
I don't know how it ever got 9.0 - all I can think of is that it copied (some of) my settings from VS2008 when I installed VS2010.  As I said previously, I did not migrate my old projects - I started from scratch and created new ones in VC2010 keeping only my personal .cpp and .h files.  Having found this "include path" bust, how do I go about changing the $(IncludePath)?
Maybe that should do it.
Thanks for your time and energy,
Ed
PS.  I did not uninstall VC2008 nor do I want to.
100 Kudos
Post 8 of 13
Re: Linker Error
04-15-2012 08:48 PM in reply to: EMD1954
You didn't say whether your platform toolset setting is correct, so I'd guess not.
Owen Wengerd
ManuSoft
Valued Contributor
2 Kudos
Post 9 of 13
Re: Linker Error
04-16-2012 05:08 PM in reply to: owenwengerd
Yes, I missed that one.
It's now set to v100.   And I set #define_WIN32_WINNT 0x0501 in stdafx.h My include path is now:
c:\Program Files\Microsoft Visual Studio 10.0\VC\VC\include
c:\Program Files\Microsoft Visual Studio 10.0\VC\atlmfc\include
c:\Program Files\Microsoft SDK's\Windows\v7.0\incl
but I'm getting the following errors:
  StdAfx.cpp
c:\Program Files\Microsoft Visual Studio 10.0\VC\atlmfc\include\afxwin.h(4060): error C2061: syntax error : identifier 'PSCROLLBARINFO'
c:\Program Files\Microsoft Visual Studio 10.0\VC\atlmfc\include\afxwin2.inl(362): error C2039: 'NotifyWinEvent' : is not a member of '`global namespace''
c:\Program Files\Microsoft Visual Studio 10.0\VC\atlmfc\include\afxwin2.inl(362): error C2660: 'CWnd::NotifyWinEvent' : function does not take 4 arguments
c:\Program Files\Microsoft Visual Studio 10.0\VC\atlmfc\include\afxwin4.inl(184): error C2065: 'PSCROLLBARINFO' : undeclared identifier
c:\Program Files\Microsoft Visual Studio 10.0\VC\atlmfc\include\afxwin4.inl(184): error C2146: syntax error : missing ')' before identifier 'pScrollInfo'
c:\Program Files\Microsoft Visual Studio 10.0\VC\atlmfc\include\afxwin4.inl(184): error C2761: 'BOOL CScrollBar::GetScrollBarInfo(void) const' : member function redeclaration not allowed
c:\Program Files\Microsoft Visual Studio 10.0\VC\atlmfc\include\afxwin4.inl(184): error C2059: syntax error : ')'
c:\Program Files\Microsoft Visual Studio 10.0\VC\atlmfc\include\afxwin4.inl(185): error C2143: syntax error : missing ';' before '{'
c:\Program Files\Microsoft Visual Studio 10.0\VC\atlmfc\include\afxwin4.inl(185): error C2447: '{' : missing function header (old-style formal list?)
c:\Program Files\Microsoft Visual Studio 10.0\VC\atlmfc\include\afxcmn3.inl(20): error C2065: 'CCM_SETWINDOWTHEME' : undeclared identifier
c:\Program Files\Microsoft Visual Studio 10.0\VC\atlmfc\include\afxcmn3.inl(23): error C2065: 'CCM_SETWINDOWTHEME' : undeclared identifier
c:\Program Files\Microsoft Visual Studio 10.0\VC\atlmfc\include\afxcmn3.inl(29): error C2065: 'CCM_SETWINDOWTHEME' : undeclared identifier
c:\Program Files\Microsoft Visual Studio 10.0\VC\atlmfc\include\afxcmn3.inl(46): error C2065: 'CCM_SETWINDOWTHEME' : undeclared identifier
I'm lost.  Sorry to be a pain,
Ed
Valued Contributor
2 Kudos
Post 10 of 13
Re: Linker Error
04-17-2012 06:34 PM in reply to: EMD1954
In case anyone was following this thread, here's what I did to fix everything (at least it's working so far!):
  1. I deleted the StdAfx.h file that the wizard generated when I created the new arx project.
  2. I copied the StdAfx.h file from the ARXDBG sample (which was significantly different than the one created by the ObjectARX Wizard 2012).
  3. I added the "includes" I needed from the acadStdafx.h file in ARXDBG sample.
  4. I added my local "includes"
Then I only had one error which I corrected by adding the following lines in stdafx.h:
#ifndef
_WIN32_WINNT
#define
_WIN32_WINNT 0x0601
#endif
FYI, the wizard generated file defined it as 0x0400.  I previously had errors that said I needed it to be 0x0501.  I found in the SDK V7.0A that it should be 0x0601.
Works fine.  Hope someone finds this useful,
Ed
PS.  Owen, thanks for all of your suggestions.
