ObjectARX
473 Views, 4 Replies
Jig method
Can I use Jig method directly without redraw it?
4 REPLIES 4
Dear wh...,
a Object derived from AcEdJig is a dragger for Object Creation and for Object manipulation.
Hello TomBengsch,
Do you have some examples except the samples in objectarx about jig.Because the result is not the same as it shows in AutoCAD.For example, when drawing a line, there is dynamic input if you click the related button, but it is not shown in my custom entity.
I don't hink, but I never try. If you use the normal way you manipulate in the Jigger  the base datas from your object. Then your object draw themself in the subWorldDraw Method, with the manipulated datas.
Oh,thank you,thanks a lot.
”Boost
