ObjectARX
whdxcg
472 Views, 4 Replies
Jig method
Can I use Jig method directly without redraw it?
4 REPLIES 4
in reply to: whdxcg
Dear wh...,
a Object derived from AcEdJig is a dragger for Object Creation and for Object manipulation.
whdxcg
Hello TomBengsch,
Do you have some examples except the samples in objectarx about jig.Because the result is not the same as it shows in AutoCAD.For example, when drawing a line, there is dynamic input if you click the related button, but it is not shown in my custom entity.
in reply to: whdxcg
I don't hink, but I never try. If you use the normal way you manipulate in the Jigger  the base datas from your object. Then your object draw themself in the subWorldDraw Method, with the manipulated datas.
whdxcg
Oh,thank you,thanks a lot.
”Boost
