hi all,
I'm new to ObjectArx. I've downloaded ObjectArx2014 , opened the sample "database/ents_dg" and built it.
Then I tried to load the "ents.arx" in AutoCAD 2014, there showed the message of incompatibility.
I'm working on a 64 bit Win7 machine, and visual studio 2012, visual studio 2010 sp1 were installed.
Thanks for help.
Solved by zhangxi27. Go to Solution.
Did you build and load the x64 binary? What is the error message?
hi Owen,
Thanks for your help.
I've found that i just forgot to config the platform into x64, so after changing it i can build and run the sample now.
