Hi,sir
my envirment is vs2008 sp1 AUTOCAD 2010 .
and I build up a program in arx with "hello world".but the acad CAN NOT load it.because it is incompatible.
How can I fix it?
Is there any library ,course, document about how to build a program for CAD?
Thank you SO MUCH!
Jason
The ObjectARX SDK documentation is in the \docs subfolder. I recommend to install and use the ObjectARX wizard (in utils\ObjectARXWiz) to create your new ObjectARX projects, as it does much of the work for you.
Hi,Wengerd
I do use the wizard create the project.
what's more, the samples in folder object2010 can not run in autoCAD2010 either because the compatible problem.
Is there any step by step tutorial?
thanks
Jason
Sorry, I don't have any information about tutorials. Perhaps if you provide details about the specific problem you're having, someone can suggest a solution.
Are you trying to load an x86 binary into an x64 AutoCAD process? That would certainly result in the error you're receiving.
