ObjectARX
How to register the “ClassDictionary of AcBrEntity” ?
3 REPLIES 3
diagodose2009
523 Views, 3 Replies
How to register the “ClassDictionary of (cBrEntity” ?
You search ??? atmy source VisualC++s.
#include "brgbl.h"
#include "brent.h"
#include "brtrav.h"
#include "brment.h"
#include "brsample_pch.h"  //precompiled header
[source]
AcRx::AppRetCode acrxEntryPoint(AcRx::AppMsgCode msg, void* pkt)
    switch (msg) {
    case AcRx::kInitAppMsg:
        asserte("G170");
        acrxDynamicLinker->unlockApplication(pkt);
      acrxDynamicLinker->registerAppMDIAware(pkt);
        //initAsdkIconSamp();
        initApp();
      if (!(acrxClassDictionary->at(_T("AcBrEntity"))))
        asserte("G240");
            if (acrxDynamicLinker->loadModule(_T("libacbr.dll"), 1)) ?????
                  ads_printf(_T("\nLoadLibraryEx(\"libacbr.dll\")=ok"));
            else
                  ads_printf(_T("\nLoadLibraryEx(\"libacbr.dll\")=failed g240err\n"));
        asserte("G241");
            if (acrxClassDictionary->at(_T("AcBrEntity")))  ????
                  ads_printf(_T("\nRegisterClassDictionary(\"libacbr.dll\")=ok\n"));
             else
                  ads_printf(_T("\nRegisterClassDictionary(\"libacbr.dll\")=failed g241err\n"));
            break;
[/source]
At text screen (at line command):
[source]
AcRxDynamicLinker failed to load 'libacbr.dll'
LoadLibraryEx("libacbr.dll")=failed g240err
RegisterClassDictionary("libacbr.dll")=failed g241err
[/source]
Best regards.
Tags (2)
3 REPLIES 3
Maybe instead of "libacbr.dll" you have to use "acbrNN.dbx" (NN is 17 for AutoCAD 2007...2009, 18 - for AutoCAD 2010...2012 and 19 for AutoCAD 2013) ?
Facebook | Twitter | LinkedIn
Expert Elite Member
Thank you., for your replay.....
Smiley Tongue
I found the solution  ,myself
[source]
 #define DLLNAME_ACBR "acbr17.dbx"
       initApp();
        if (acrxDynamicLinker->loadModule(_T(DLLNAME_ACBR), 1))
            ads_printf(_T("\nLoadLibraryEx(\"DLLNAME_ACBR\")=ok"));
        else
            ads_printf(_T("\nLoadLibraryEx(\"DLLNAME_ACBR\")=failed g240err\n"));
[/source]
owenwengerd
in reply to: diagodose2009
If your module has a dependency on the acbr17.dbx module, then you should be calling loadModule() regardless whether it is already loaded (and call unloadModule() when your dependency expires).
Owen Wengerd
ManuSoft
”Boost
