ObjectARX
Message 1 of 5 (115 Views)
how to insert a point on a spline
115 Views, 4 Replies
09-04-2012 02:44 AM
I can't find any good method to insert a point on a spline, please see the code below.  I want to insert a point on an existing spline, and after insertion ,the shape of the spline shoud not change much.
AcDbObjectId idSpline;
        if (!Acad_Selection::smileyfrustrated:elEnt(idSpline,_T("spline")))
            return;
        AcDbSplinePointer pSpline(idSpline,AcDb::kForWrite);
        if (Acad::eOk != pSpline.openStatus()) return;
        ads_point pt;
        if (acedGetPoint(NULL,_T("\nclick:"),pt) != RTNORM)
            return;
        AcGePoint3d pt3d;
        pSpline->getClosestPointTo(asPnt3d(pt),pt3d);
        double dParam = -1;
        pSpline->getParamAtPoint(pt3d,dParam);// here , the value of dParam is not what I want.
        acutPrintf(_T("\n%g,round:%d,floor:%d,ceil:%d"),dParam,int(dParam+0.5),floor(dParam),ceil(dParam));
        pSpline->insertFitPointAt(floor(dParam),pt3d);
Technology change world! Coding change technology! We coders are coding!
Distinguished Mentor
owenwengerd
Message 2 of 5 (112 Views)
Re: how to insert a point on a spline
09-04-2012 05:28 AM in reply to: 421232206
What is your overall goal, and what exactly is the problem with the code you posted?
Owen Wengerd
ManuSoft
Message 3 of 5 (105 Views)
09-04-2012 07:59 AM in reply to: 421232206
my purpose is to insert a fit point to the spline. I get get closest point P1 on the spline for the point I click on the screen.
but  through the method getParamatPoint, the param I got of P1 has nothing to do with the fit point. I want to use insertFitPointAt. and insertFitPointAt requires the number of fit point.  is there an existing method that can return which two fit points P1 is between.
owenwengerd
Message 4 of 5 (100 Views)
09-04-2012 11:03 AM in reply to: 421232206
There is no existing method to do that directly. You did not describe your overall goal, so I can't offer any alternative solutions.
Owen Wengerd
ManuSoft
Message 5 of 5 (92 Views)
09-04-2012 06:10 PM in reply to: 421232206
oh, if so , I have to calculate the "param" for each fit point, then compare these params with the insert point and determine which fit point is the right one for "insertFitPointAt".
still,thanks a lot.
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
