I have a scenario, where using a same command I have draw and edit of our entities.
If nothing is selected during firing the command, insert mode will be activated where a block will be inserted with attribute values from UI.
But if the block is selected and the command is invoked, the attributes will be read and be populated in the UI and the UI will work as an editor.
I have used acedGetCurrentSelectionSet. Its working fine when something is all ready selected before firing the command.
But next time when nothing is seleted, it still, considers, the previous selection as the current selection, which is not correct.
So what is the correct API to get the currect selection.
NB: I only want the 1st entity in the selection set, I don't want to iterate through the selection set.
I have used the following code.
static void InvokeMainUI(void)
AcDbObjectIdArray CurrSelSet;
Acad::ErrorStatus es = acedGetCurrentSelectionSet(CurrSelSet);
try
if(!CurrSelSet.isEmpty() )//Something is selected, so start in edit mode
AcDbObjectId objID = CurrSelSet.at(0);
AcDbEntity *pEnt;
acdbOpenAcDbEntity(pEnt,objID,AcDb::kForRead);
if (pEnt->isKindOf(AcDbBlockReference::desc()))
CNSDWGMgr ThisDrawing;
ThisDrawing.SubStnBlokEdit(pEnt);// Edit Mode
pEnt->close();
else // nothing is selected, so start with out editing mode
MYSTRINGSTRINGMAP mapOfAttributesFromRegistry;
//getAttributeInfoFromWithInBlock(mapOfAttributesFromRegistry);
CAcModuleResourceOverride myResources;
CNSMainSubstaionDlg* objDlg = new CNSMainSubstaionDlg(mapOfAttributesFromRegistry,acedGetAcadFrame());
if(objDlg!=NULL)
objDlg->DoModal();
delete objDlg;
CurrSelSet.removeAll();
CurrSelSet.removeSubArray(0,CurrSelSet.length());
catch(...)
Hello Subir,
Have you tried using the pick-first selection set for this ?
The command that runs this code must specify ACRX_CMD_USEPICKSET
Here is a sample code :
structresbuf * ss = NULL;
if(RTNORM != acedSSGetFirst(NULL, &ss))
return;
longlen;
if(RTNORM != acedSSLength(ss->resval.rlname, &len))
acedSSFree(ss->resval.rlname);
acutRelRb(ss);
return;
if(len < 1)
acutRelRb(ss);
return;
BOOL ret = TRUE;
for (longi = 0; i < len; i++)
ads_name name;
acedSSName(ss->resval.rlname, i, name);
AcDbObjectId id;
acdbGetObjectId(id, name);
acutRelRb(ss);
Cheers,
Balaji
Developer Technical Services
