ObjectARX
How to get the (2D) projection of a solid?
2 REPLIES 2
maisoui
606 Views, 2 Replies
After several tests / research, I still can not correctly calculate the (2D) projection of a solid. For example, I want to obtain a circle/ellipse for a sphere (with or without obscured lines) (something similar to command FLATSHOT). I tried to use Brep API, but without success (execution time very very long or eDegeneratedTopology error).
My goal is to display any projection of a given solid in a custom entity. Perhaps there is a simple way in subWorldDraw or subViewportDraw?
Several posts in the forum talks about the same topic, but were never answered.
Any suggestions are welcomed. Regards,
Jonathan
2 REPLIES 2
dgorsman
in reply to: maisoui
I *think* what you're looking for is the HLR API (hidden line removal).
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
maisoui
in reply to: dgorsman
Perfect. This is exactly what I was looking for. After reading the few Hlr examples that come with the API, I was able to implement a 2D projection of a solid, and it computes fast.
Many thanks for your help.
Jonathan
”Boost
