How to get annotative scale value from dimension?
How to get annotative property from dimension?
plz provide some sample code!!!
Solved by Alexander.Rivilis. Go to Solution.
static void CheckAnnotative(void) { ads_name en; ads_point p; if (acedEntSel(_T("\nSelect annotative entity: "),en,p) != RTNORM) return; AcDbObjectId eid; acdbGetObjectId(eid,en); AcDbEntityPointer pEnt(eid,AcDb::kForRead); if (pEnt.openStatus() != Acad::eOk) return; AcDbAnnotativeObjectPE *ann = ACRX_PE_PTR(pEnt, AcDbAnnotativeObjectPE); if (ann && ann->annotative(pEnt)) { AcDbObjectContextInterface *objInt = ACRX_PE_PTR(pEnt, AcDbObjectContextInterface); if (objInt) { AcDbObjectContextManager *cManager = acdbCurDwg()->objectContextManager(); if (cManager) { AcDbObjectContextCollection *col = cManager->contextCollection(ACDB_ANNOTATIONSCALES_COLLECTION); if (col) { AcDbObjectContextCollectionIterator* iter = col->newIterator(); if (iter) { for (iter->start(); !iter->done(); iter->next()) { AcDbObjectContext *cont = NULL; iter->getContext(cont); if (cont) { AcDbAnnotationScale *pScale = AcDbAnnotationScale::cast(cont); if (pScale && objInt->hasContext(pEnt,*pScale)){ double scale = 1; pScale->getScale(scale); double pUnits = 1; pScale->getPaperUnits(pUnits); double dUnits = 1; pScale->getDrawingUnits(dUnits); AcString name; pScale->getName(name); acutPrintf(_T("\nName = <%s> Scale = %g PaperUnits = %g DrawingUnits= %g"), name.kACharPtr(), scale, pUnits, dUnits); } } } delete iter; } } } } } else { acutPrintf(_T("\nNot annotative entity!")); } }
Minimum error checking done.
ObjectARX SDK 2008 and 2009 has sample: samples\misc\AnnotationScaling
In order to download those old versions of ObjectARX SDK and and see this sample: http://goo.gl/XtJ2x
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
