ObjectARX
How to get an UCS of entity
3 REPLIES 3
kimi
310 Views, 3 Replies
Hi all,
How to get an UCS in which entity is drawn ?
OR
How to set UCS to the ucs in which selected entities are drawn ?
Thanks in advance.
KIMI
3 REPLIES 3
in reply to: kimi
Try this code:
[code]
static void SetECSasUCS(void)
Acad::ErrorStatus es;
ads_name en; ads_point p;
if (acedEntSel("\nSelect entity: ",en,p) == RTNORM) {
AcDbObjectId eId; acdbGetObjectId(eId,en);
AcDbObjectPointer pEnt(eId,AcDb::kForRead);
if ((es = pEnt.openStatus()) == Acad::eOk) {
if (pEnt->isPlanar()) {
AcGePlane plane;
AcDb::Planarity planetype;
if ((es = pEnt->getPlane(plane,planetype)) == Acad::eOk) {
AcGeMatrix3d ucs; ucs = AcGeMatrix3d::planeToWorld(plane);
AcGePoint3d org;
AcGeVector3d xdir,ydir,zdir;
ucs.getCoordSystem(org,xdir,ydir,zdir);
acutPrintf("\nUCSORG=%g,%g,%g\nUCSXDIR=%g,%g,%g\nUCSYDIR=%g,%g,%g\nUCSZDIR=%g,%g,%g",
org.x,org.y,org.z,xdir.x,xdir.y,xdir.z,ydir.x,ydir.y,ydir.z,zdir.x,zdir.y,zdir.z);
// Setting ECS coordinat system as UCS
acedSetCurrentUCS(ucs);
} else {
acutPrintf("\npEnt->getPlane(plane,planetype)=%s", acadErrorStatusText(es));
} else {
acutPrintf("\nEntity is not planar!");
} else {
acutPrintf("\npEnt.openStatus()=%s", acadErrorStatusText(es));
[/code]
in reply to: kimi
Kimi,
Look at me Kimi try getting the object normal!
pEnt->normal();
If you can't get the normal then it is a 3d object that does not
need the UCS.
Regards Gary
www.drcauto.com
wrote in message news:5100165@discussion.autodesk.com...
Hi all,
OR
Thanks in advance.
KIMI
kimi
in reply to: kimi
Thanks a lot Gary and Alexander !!!
Alexander,
I will try your suggestion and let you know the result soon..
KIMI
”Boost
