ObjectARX
*Bhatia, Manish
Message 1 of 8 (351 Views)
How To Find Memory Leak in ARX File
351 Views, 7 Replies
08-04-2002 01:21 PM
Dear Friends
Can Some One Tell How To Find Memory Leak in ARX File.
*Malard, Fernando
Message 2 of 8 (351 Views)
Re: How To Find Memory Leak in ARX File
08-05-2002 01:21 AM in reply to: *Bhatia, Manish
Try this:
_CrtDumpMemoryLeaks();
Take a look at VC++ documentation for further information...
Fernando.
"Manish Bhatia" wrote in message
news:f0fea75.-1@WebX.maYIadrTaRb...
> Dear Friends
*Matthias, Joel
Message 3 of 8 (351 Views)
Re:
08-05-2002 04:20 AM in reply to: *Bhatia, Manish
Again this function is defined only in the debug C-runtime library. A
correctly set up ARX DLL must link with the release C-runtime library where
this function is not available. Am I missing something here?
Joel
"Fernando Malard" wrote in message
news:CF72F037C6E5B94EC66D19038F148B17@in.WebX.maYIadrTaRb...
> Hello,
> Try this:
> Regards,
> Fernando.
> > Dear Friends
*Kohut, Paul
Message 4 of 8 (351 Views)
12-13-2003 08:16 PM in reply to: *Bhatia, Manish
If you have a few hundred dollars to blow, then buy BoundsChecker
from Numega. Otherwise, view the debug tab in the IDE after
Autocad quits. Scroll up a ways looking for memory leak messages.
Memory leaks will be reported as the line that allocated the memory.
From there your on your own figuring out why the memory wasn't
deallocated.
Paul Kohut
> Dear Friends
*Matthias, Joel
Message 5 of 8 (351 Views)
Re:
Correct me if I am wrong but you cannot find memory leaks using MFC's leak
detection since you are linked with the release version of MFC. Maybe I have
been missing something for 2 years now (that's possible!).
Joel
"Paul Kohut" wrote in message
news:5C1DC5575F162F8B800A7EEBB9D1D42A@in.WebX.maYIadrTaRb...
> deallocated.
> Paul Kohut
> > Dear Friends
*Bihan, Andrew le
Re:
Make sure you have this at the top of your implementation files:
#ifdef _DEBUG
#define new DEBUG_NEW
#undef THIS_FILE
static char THIS_FILE[] = __FILE__;
#endif
Andy
> deallocated.
> Paul Kohut
> > Dear Friends
*Kohut, Paul
Message 7 of 8 (351 Views)
Re:
Your right. Had memory fade there for a minute. I've
been using Bounds Checker for a couple years with
good success.
Paul Kohut
"Joel Matthias" wrote in message
news:0D142017C0F7269EBF48F0102B6F1389@in.WebX.maYIadrTaRb...
have
> Joel
> > deallocated.
> > Paul Kohut
> > > Dear Friends
Active Member
kvenics
Message 8 of 8 (278 Views)
Re: Re: Find memory leaks in arx file
01-29-2013 11:20 PM in reply to: *Kohut, Paul
Manish Bhatia,
I used Purify but it doesn't support arx files.
Were you able to find memory leaks in arx files? Please share your experience. Didn't get much info. on the net.
--Thanks,
Pramila
