ObjectARX
How to extrude a AcDb3dSolid and retreive informations ?
1 REPLY 1
Yann458
758 Views, 1 Reply
I'am newed in this forum.
I need your help,
I will wish to develop a low-level primitives extruder from AcDb3dSolid entity.
I am searching for a C,C++ objectarx's sample or information in order for extract the primitive vertex x, y, z and texture u, t since a AcDb3dSolid entity .
Why? I want to export AcDb3dSolid entity to a private DAT file containing vertex x, y, z and texture alignment u, t,
in order for future displaying it in OpenGL (this is my problem).
Thank you very much.
1 REPLY 1
Balaji_Ram
in reply to: Yann458
Welcome to the ObjectARX forum !
To retrieve information from the AcDb3dSolid, you can use the BRep API. There is a sample in the ObjectARX SDK folder under "utils\brep\samples\brepsamp”".
Also, this blog post can help.
http://adndevblog.typepad.com/autocad/2013/01/get-points-from-a-region-solid-or-body-in-objectarx.ht...
About your other query on retrieving the UV coordinates of the texture, unfortunately this is not possible at present.
http://forums.autodesk.com/t5/NET/Obtaining-texture-UV-coordinates/m-p/4463361#M37134
Balaji
Developer Technical Services
Autodesk Developer Network
”Boost
