ObjectARX
ObjectARX
maisoui
Message 1 of 3 (387 Views)
How to draw a custom glyph near the AutoCAD crosshair cursor?
387 Views, 2 Replies
12-06-2012 02:56 AM
I have complex custom entities and I'd like to implement advanced manipulation like grip points of Polyline. I'm looking for how to draw a custom glyph neer the AutoCAD crosshair cursor, like AutoCAD does when you convert a polyline segment to an arc or you add a vertex (look at the image below).
All suggestions are welcomed.
Best regards,
Jonathan
Jonathan
I was able to implement that I wanted by combining an AcEdInputPointMonitor and a Transient Entity. Have a look to sample AsdkTransientGraphicsSampFolder of OARX 2009. In method monitorInputPoint you have to update the position of the transient entity and that's it.
Note: If you use kAcGiDirectTopmost as drawing mode (when adding transient), entity will be drawn over grips.
I hope this will help somebody else.
Jonathan
Moderator
Alexander.Rivilis
Message 2 of 3 (381 Views)
Re: How to draw a custom glyph near the AutoCAD crosshair cursor?
12-06-2012 04:34 AM in reply to: maisoui
For example with help of AcEdInputPointMonitor::monitorInputPoint.
Using AcGiViewportDraw* drawContext parameter you can draw yours own graphics.
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
maisoui
Message 3 of 3 (282 Views)
06-26-2013 11:35 PM in reply to: maisoui
Jonathan
Jonathan
