Hi, I need to prevent any DWG file to be opened in wich any customized
entity have a version number lower than a predefined value. I tried to use
the closeDocument() function without sucess because it can not be used while
there is another command still in process. Is there any other way to close a
DWG document or prevent it to be opened based on some entity version? I need
to prevent, both changes and saving of document. By the way, I'm usin
AutoCAD 2000 and ObjectARX2000. Thanks.
