ObjectARX
ObjectARX
Moderator
Alexander.Rivilis
Message 11 of 14 (198 Views)
Re: how to change the value of user variable of autocad2010
02-21-2013 02:29 AM in reply to: zhangxinhua789
Ok. I've tested my code from post 4 and it do it the same you ask me.
1. Compile and build arx-file with code I've posted.
2. Start AutoCAD and load arx-file into AutoCAD.
3. Starting command ADDASSOCVAR and you see how line changed.
Command: ADDASSOCVAR
Variable name: user1
Variable expression: 100
So before command:
And after command:
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Active Contributor
zhangxinhua789
Message 12 of 14 (155 Views)
02-26-2013 05:28 PM in reply to: zhangxinhua789
Thank you very much! It's very kind of you.you are my mentor.
Regards
Active Contributor
zhangxinhua789
Message 13 of 14 (147 Views)
02-26-2013 07:27 PM in reply to: Alexander.Rivilis
Hello,experts
  I have a new question,I want to know how to use the Dynamic Blocks in objectarx2010. I define a Dynamic Block in autocad2010,Now I want to insert the Dynamic Block in a dwg-file,can you tell me the code?Thank you very much!
  this is a screenshot of the Dynamic Blocks,I want to insert the Dynamic Block in the position(x=50,y=50),and I want change the three dimensions:
before command:they are d1=48;d2=96;d3=43
after  command:they are d1=98;d2=150;d3=70
I think the class of AcDbDynBlockReference is useful,but I don't know how to use it.Can you help me?
Active Contributor
zhangxinhua789
Message 14 of 14 (141 Views)
02-26-2013 11:25 PM in reply to: Alexander.Rivilis
Hello,experts
I have a new question,I want to know how to use the Dynamic Blocks in objectarx2010. I define a Dynamic Block in autocad2010,Now I want to insert the Dynamic Block in a dwg-file,can you tell me the code,Thank you very much!
this is a screenshot of the Dynamic Blocks,I want to insert the Dynamic Block in the coordinate position(x=50,y=50),and I want change the three dimensions:
And I have attached this dwg-file in my post in order to you can test your code with it(I have
defined the the Dynamic Block,its name is a;you can try to insert it in autocad2010).
Announcements
Need installation help?
