ObjectARX
ObjectARX
Active Member
JoseVicario
Message 1 of 5 (327 Views)
How to ask for a password on the command line of AutoCAD 2013 using ObjectARX?
327 Views, 4 Replies
10-06-2012 12:35 AM
How can I ask for a password, replacing each keystroke with a generic character, on the command line of AutoCAD 2013 using ObjectARX?
Thanks in advance.
Thanks Balaji for your reply. The code works well with some corrections:
The line
int key = hs.vkCode;
must be
int key = hooked_key.vkCode;
and the line
GetKeyNameText(dwMsg, &password[pwdLen], 0xFF) + 1;
must be
GetKeyNameText(dwMsg, &password[pwdLen], 0xFF);
Moderator
Alexander.Rivilis
Message 2 of 5 (317 Views)
Re: How to ask for a password on the command line of AutoCAD 2013 using ObjectAR
10-06-2012 02:58 AM in reply to: JoseVicario
Try this: http://adndevblog.typepad.com/autocad/2012/06/asking-for-a-password-on-the-command-line-of-autocad-u...
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Active Member
JoseVicario
Message 3 of 5 (312 Views)
10-06-2012 05:34 AM in reply to: Alexander.Rivilis
Thanks Alexander, but the solution in adndevblog fails in AutoCAD 2013. Look the comment by Thierry Prince below the solution.
ADN Support Specialist
Balaji_Ram
Message 4 of 5 (269 Views)
10-13-2012 09:36 AM in reply to: JoseVicario
Hi Jose,
Using hooks is a hack that is not generally advisable to use. If you have the option, switch over to a UI to take that input which you are trying to mask. That way you will not need to use hooks.
However if you still need to go this route, then here is a code snippet based on the low level keyboard hooks. Hope this helps. I havent tested it very extensively but seems to work in general using AutoCAD 2013.
Here is the sample code :
static ACHAR password[133];
static int pwdLen;
static HHOOK hKeyboardHook;
// - AdskMyTest1.MyCommand1 command (do not rename)
static void AdskTestCommand(void)
	ACHAR pwd[133];
	adskGetPassword(1, ACRX_T("Password please ?"), pwd);
static int adskGetPassword(int cronly,ACHAR* prompt,ACHAR* result)
	pwdLen = 0;
	password[pwdLen]='\0';
	HINSTANCE hInstance = GetModuleHandle(NULL);
	if (!hInstance)
		return 1;
	hKeyboardHook = SetWindowsHookEx (
										WH_KEYBOARD_LL,
										(HOOKPROC) KeyboardEvent,
										hInstance,
										NULL
	ACHAR tempResult[133];
	int ret = acedGetString(cronly, prompt, tempResult);
	UnhookWindowsHookEx(hKeyboardHook);
	if(ret != RTNORM)
		acutPrintf(ACRX_T("\nCancelled."));
	else
		password[++pwdLen] = '\0';
		acutPrintf(password);
	wcscpy(result, password);
	return ret;
static LRESULT CALLBACK KeyboardEvent (int nCode, WPARAM wParam, LPARAM lParam)
	if ((nCode == HC_ACTION) &&
	((wParam == WM_SYSKEYDOWN) ||
	(wParam == WM_KEYDOWN)))
		KBDLLHOOKSTRUCT hooked_key = *((KBDLLHOOKSTRUCT*)lParam);
		DWORD dwMsg = 1;
		dwMsg += hooked_key.scanCode << 16;
		dwMsg += hooked_key.flags << 24;
		if ((key >= 'A' && key <= 'Z')  || (key >= '0' && key <= '9'))
			keybd_event(VK_MULTIPLY, hooked_key.scanCode, hooked_key.flags, 0);
			return 1;
		else if(hooked_key.vkCode == VK_BACK)
			password[--pwdLen] = '\0';
	return CallNextHookEx(hKeyboardHook, nCode,wParam,lParam);
Balaji
Developer Technical Services
Autodesk Developer Network
Active Member
JoseVicario
Message 5 of 5 (257 Views)
10-13-2012 11:05 AM in reply to: Balaji_Ram
The line
must be
and the line
must be
