ObjectARX
How do I change the line type of a line in C#?
2 REPLIES 2
2020 Views, 2 Replies
I am new to C# and new to .NET for AutoCAD. Trying to do some basic stuff I've done in other APIs.
I have this line of code that compiles fine:
leftLine.Linetype = Autodesk.AutoCAD.GraphicsInterface.Linetype.Dashed.ToString();
 However, on execution, it returns an error with 'eKeyNotFound'.
Further, the ToString method has a note in the Visual Studio editor; "This method is obsolete, use System.Enum.Parse(System.Type, System.String);" No luck so far figuring out that one.
Thanks in advance for any help.
Eric
2 REPLIES 2
fenton.webb
The following code snippet in a C# project shows how to load the linetype from a linestyle file:
[CommandMethod("test")]
static public void test()
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
Database db = HostApplicationServices.WorkingDatabase;
Transaction trans = db.TransactionManager.StartTransaction();
try
HostApplicationServices.WorkingDatabase.LoadLineTypeFile("DASHED", "acad.lin");
LinetypeTable tbl = (LinetypeTable)trans.GetObject(db.LinetypeTableId,OpenMode.ForRead);
ObjectId id = ObjectId.Null;
if (true == tbl.Has("DASHED")) id = tbl["DASHED"];
ed.WriteMessage("\nDASHED lintype objectid is:" + id.ToString());
trans.Commit();
catch
finally
trans.Dispose();
Fenton Webb
Autodesk Developer Network
Fenton Webb
AutoCAD Engineering
bojan_p87
in reply to: fenton.webb
hello fenton webb i need to create linetype "dot(space)continuos(space)dot" - line with space betwen dot and continuos line space ned to be lenght for example 0.25 units i hawe this line of code and its adding new line with name Gline and load it but my problem is i can't create this shape pf line can you help me?
Code:
[CommandMethod("Glinija")]
        static public void Glinija()
            Document acDoc = Application.DocumentManager.MdiActiveDocument;
            Database acCurDb = acDoc.Database;
            Transaction acTrans = acCurDb.TransactionManager.StartTransaction ();
                LinetypeTable acLintypeTbl = acCurDb.LinetypeTableId.GetObject(OpenMode.ForWrite) as LinetypeTable;
                 LinetypeTableRecord Lin = new LinetypeTableRecord();
                Lin.Name = "Glinija";
                Lin.Comments = "Glinija";
                Lin.AsciiDescription = "Line with space froam dot";
this i cannot to acomplish i ned "dot,emptySpace,continuos,emptySpace"
                acLintypeTbl.Add(Lin);
                acTrans.AddNewlyCreatedDBObject(Lin, true);
                acTrans.Commit();
”Boost
