ObjectARX
How can we get model space scale value?
3 REPLIES 3
varadan01
647 Views, 3 Replies
In AutoCad Mech we can set model space value by using AMSYMSCALE command ,they set model space scale value. Check this command AMSYMSCALE in Mech or type option in AM:Standard tab you can find Model Space.
In Autocad how can we get model space value?
With Regards,
GVaradarajan
3 REPLIES 3
fenton.webb
in reply to: varadan01
Have you checked out DIMSCALE
Fenton Webb
AutoCAD Engineering
varadan01
in reply to: fenton.webb
Ya but in autocad mech dimscale is not updated..if u go to option
am::standard tab the model space label check update layout value..then ly
dimscale value'll change depend upon the amsymscale. Like this any model
scale value for AutoCad Vanilla version.
"The most loveliest life is living with the person who loves u.."
"The most loveliest death is dying in the arms of the one you love!!.."
With Regards,
GVaradarajan
With Regards,
GVaradarajan
dgorsman
If this is for vanilla AutoCAD, it doesn't have the concept of "model space scale".  Hence the implementation in Mechanical and other programs.  Many third-party developers will use the DIMSCALE value for the active dimension style as the current scale, since they are usually the same.
”Boost
