ObjectARX
Get Type of AcDb3dSolid in ObjectARX, Get Primitive-Type from 3Dsolid?
4 REPLIES 4
diagodose2009
1135 Views, 4 Replies
Hi...
I need help   ,
i want determine type of  AcDb3dSolid.. in ACHAR *.
You replace "???" with other function.. in first source
The  routine C++ARX ,wiil  set result=_T("Cylindre"") or ("Sphere")..or ("Torus")..
VC++2010 .. display the message:
                            l:\1user\arx2010\i(32): error C2039: 'SolidType' : is not a member of 'AcDb3dSolid'
Regards...
Smiley Embarassed
[source=cpp ObjectARX ]
ACHAR * result=nil;
 AcDb3dSolid * pSolid=nil;
  pSolid = (AcDb3dSolid *)pObj;
  if (pSolid==nil)
    { pObj->close();
      pObj=nil;
      exitif(1,"g334.error 3d");
  if (pSolid->isNull)
    { pObj->close();
      pObj=nil;
      exitif(1,"g334.error nil");
  result=pSolid->SoildType()????
  pObj->close();
  pObj==nil;
  pSolid->close();
  pSolid=nil;
[/source=cpp ObjectARX ]
Smiley Frustrated
I found Visual LISP  source,bellow:
[source=visual-lisp ]]
(vl-load-com)
(if (and
      ;; solid selection
      (setq cyl (car (entsel "\nSelect a cylinder: ")))
      ;; changing ename to vla-object
      (setq cyl (vlax-ename->vla-object cyl))
      ;; checking if it's a 3d solid
      (= (vla-get-ObjectName cyl) "AcDb3dSolid")
      ;; checking if it's a cylinder (primitive)
      (= (vl-catch-all-apply 'vla-get-SolidType (list cyl))
     "Cylindre"
  (setq
    ;; cylinder height
    ht    (* 2
       (distance (vlax-get cyl 'Position) (vlax-get cyl 'centroid))
    ;; cylinder radius
    rad    (sqrt (/ (vla-get-Volume cyl) (* pi ht)))
  (princ "\nUnvalid Entity.")
[/source=visual-lisp ]
4 REPLIES 4
How to obtain AcDb3dSolid OPM Properties in AutoCAD using ObjectARX/C++
Facebook | Twitter | LinkedIn
Expert Elite Member
I  found   the functions:
#define IAcad3DSolid_get_SolidType(This,solidType)    \
    ( (This)->lpVtbl -> get_SolidType(This,solidType) )
from the file : axdb.h
dziwve67853
in reply to: diagodose2009
Can you give me a sample to show how to use the IAcad3DSolid_get_SolidType? Thank you!
https://forums.autodesk.com/t5/objectarx/how-to-get-the-text-content-generated-by-the-list-command/t...
Trapping The Output From The AutoCAD Text Screen / Command Prompt
Thank you! I can get the answer.
”Boost
