ObjectARX
Get the list() result
2 REPLIES 2
373 Views, 2 Replies
Hi everybody
i need to get the result of the list() method in my application in order to modify it for a better view from the user.
is there any way to redirect the editor output stream or maybe to read the content of the editor?
thanks
2 REPLIES 2
StephenPreston
If you just want to change the text output from an entity when you LIST it, then you could create an AcDbPropertiesOverrule and override the list() function.
Cheers,
Stephen Preston
Autodesk Developer Network
Alexander.Rivilis
giackserva wrote:
...is there any way to redirect the editor output stream or maybe to read the content of the editor?...
Yes. http://adndevblog.typepad.com/autocad/2012/09/trapping-the-output-from-the-autocad-text-screen-comma...
Facebook | Twitter | LinkedIn
Expert Elite Member
”Boost
