ObjectARX
Generating an Entities GUID
1 REPLY 1
543 Views, 1 Reply
Many of the Autodesk Products use GUID's to identify Entities/Objects.
Whilst Revit internally utilses unique identifers (not specifically GUID's) the API has a number of tools to allow the GUID's it creates on export to be generated.
GUID's in Revit in some instances are created by XORing the EpisodeID with the ElementID, I tried this logic in AutoCAD (XORing the DrawingFingerGuid with the Handle) but this results in a different GUID to the one created on IFC export (I appreciate the IFC export GUID is encoded but essentially its the same GUID) which should also be the same as the GUID that is associated with entities when imported into Navisworks.
So what I am after is a method to generate GUID's for AutoCAD entities, A method that will result in the same GUID that gets assiged on IFC export (it doesn't necessarily have to be converted to the IFC compliant GUID), or creates the GUID that gets created on import to Navisworks (it should be the same method for both versions of the GUID)
Many Thanks
Paul M
1 REPLY 1
fenton.webb
You may want to consider posting this question to the Revit forum, where presumably some AutoCAD peeps have moved to Revit and may know the answer :-S
Fenton Webb
AutoCAD Engineering
”Boost
