I have figured out how to use the basics of the acutbuildlist command based on the documentation and online examples. What I am having trouble finding is anything beyond getting a simple object. What I want to do is get get all of the closed polylines. I can get all polylines and then iterate through them testing whether they are closed or not, but I think this is inefficient.
Along the same lines, is there a reference somewhere that explains all of the codes and what they are used for? Like the code for the radius of a circle is 60. Why? Where is that defined? Is 60 used for anything else?
I've looked in the ObjectARX reference and is says that you need to use valid Drawing Interchange Format (DXF) group codes, but doesn't say what they are or where to find them.
Details, man! I need details!
I should also say that if this isn't a good way to get different object types in the drawing, then let me know what would be better...
Thanks!
- Matt
