I make an object to store some general information in the NOD. Everything seem fine, object created, store in the NOD and I can get information store in that. The problem happen when I want to modify the data in the store object. Whenever I start to modify data it alway return error say that "INTERNAL ERROR: !dbobji.cpp@7171: eNotOpenForWrite" when ever run to the redline.
Please help.
void DlgLandType::OnBnClickedOk()
// TODO: Add your control notification handler code here
UpdateData(TRUE);
if ((m_Name.GetLength()<1)) {
MessageBox(_T("Input Name of Land Type"),_T("Error"),0);
return;
AcDbObjectId objId = NULL;
AcDbDictionary *pNamedobj = NULL;
AcDbDictionary *pDict = NULL;
KMTLANDTYPE *pObj=NULL;
//KMTArxUtils_GetDictionaryObjectId(objId,m_Name.GetBuffer(),_T("KMT_LAND_TYPES")); //if exist open if not create, return objId
//m_Name.ReleaseBuffer();
acdbHostApplicationServices()->workingDatabase()->
getNamedObjectsDictionary(pNamedobj, AcDb::kForRead);
if (pNamedobj->getAt(_T("KMT_LAND_TYPES"), (AcDbObject*&) pDict, AcDb::kForWrite) == Acad::eKeyNotFound) {
pNamedobj->upgradeOpen();
pDict = new AcDbDictionary;
AcDbObjectId DictId;
pNamedobj->setAt(_T("KMT_LAND_TYPES"), pDict, DictId);
pNamedobj->close();
pDict->close();
else{
pNamedobj->close();
AcDbDictionaryIterator* pDictIter= pDict->newIterator();
CString val;
for (; !pDictIter->done(); pDictIter->next()) {
//pDictIter->getObject((AcDbObject*&)pObj,AcDb::kForRead);
acdbOpenObject((AcDbObject*&)pObj,pDictIter->objectId(),AcDb::kForRead);
if ((pObj!=NULL)&&(0==(pObj->getName().CompareNoCase(m_Name)))){
objId=pObj->objectId();
//pObj->close();
break;
else {
if (pObj!=NULL) {
pObj->close();
delete pDictIter;
if (pDict) {
pDict->setTreatElementsAsHard(true);
if (objId == NULL){
pObj = new KMTLANDTYPE();
else
pObj->upgradeOpen(); //acdbOpenObject((AcDbObject*&)pObj,objId,AcDb::kForWrite );
pObj->setName(m_Name); <- Error happen here.
pObj->setFunction(m_Function);
pObj->setObjectColor(m_Color);
pObj->setLayerIdByName(m_LayerName);
pObj->setHatchName(m_HatchName);
pObj->setHatchScale(m_HatchScale);
pObj->setHatchColor(m_HatchColor);
pObj->setHatchRotation(m_HatchRotation*PI/180);
pObj->setPowerConsumption(m_PowerConsumption);
pObj->setPowerConsumption2(m_PowerConsumption2);
pObj->setWaterConsumption(m_WaterConsumption);
pObj->setWaterConsumption2(m_WaterConsumption2);
pObj->setPowerSupplyByBuilding(m_PowerSupplyByBuilding==TRUE ? true : false);
pObj->setWaterSupplyByBuilding(m_WaterSupplyByBuilding==TRUE ? true : false);
pObj->setGroupId(m_GroupId);
AcDbObjectId rId;
if (objId == NULL){
pDict->setAt(m_Name, pObj, rId);
pObj->close();
pDict->close();
if (cb_Name.FindString(0,m_Name.MakeUpper().Trim())<0)
cb_Name.AddString(m_Name);
UpdateData(FALSE);
//OnOK();
Solved by owenwengerd. Go to Solution.
It looks like you intended your "else" statement to have a longer scope than just one line. Or maybe you just need to check the return value of upgradeOpen()?
Thanks Owen, I check the return value of UpgradeOpen() and get eHadMultipleReaders. Please help.
Dear Owen,
Since the result from UpgradeOpen(), I have check all the code from other fuction and found in one place, my object was open but I forgotten to close.
Thank you very much of the sugeestion for the checking return value from the object function calling,
