ObjectARX
Entities Selection, using acedSSGet function or another function
7 REPLIES 7
Message 1 of 8
1744 Views, 7 Replies
Hi All,
I am trying to use the function acedSSGet(...) in order to get a specific
selection set of entities ONLY from the current space (MS, Layout1,
Layout2...).
The help says: "if you use the "X" option, acedSSGet() scans the entire
drawing database."
I used the Selection code "A" (ALL) that is supposed to give me a different
result.
In AutoCAD the "select objects: All" returns all the entities in the current
space.
How can I get the selection?
Do you have any suggestions?
Thanks a lot,
Nirit
7 REPLIES 7
Message 2 of 8
jlobo2
Hi Nirit,
Am stuck in the same problem. Was wondering if you got any solution for the same?
I am using acedSSGet(_T("A"), NULL, NULL, NULL, nameOfSelectionSet); to get everything in the selectionSet.
Then accessing it by
for(long cnt = 0; cnt < lengthOfSelectionSet; cnt++)
    acedSSName(nameOfSelectionSet, cnt, nameOfEntity);
    acdbGetObjectId(idOfEntity, nameOfEntity); // Here it does not return the id
Message 3 of 8
nick83
sample for crossing polygon.
ads_name ent;
struct resbuf lookAt;
lookAt.restype = 67;
lookAt.resval.rint = model_or_layout() ? 0 : 1; // 0 - modelspase, 1 - current paperspace
lookAt.rbnext = NULL;
if(acedSSGet(_T("_cp"), pointlist, NULL, &lookAt, ent) != RTNORM)
acutPrintf(_T("\n terminated by user"));
return;
// here you can use set of selected entities from "ent"
Message 4 of 8
jlobo2
Thanks for your reply Nick,
What points do pointList represent?
What I am trying to do is, access all the entities in the current drawing, when the user runs a particular ObjectArx program and then do some changes in the Block References.
Do you think of any other way to achieve the same.
Message 5 of 8
nick83
in reply to: jlobo2
this variant is for selecting entities within a polygon
 if you want to select everything for curret space, your code have to be
if(acedSSGet(_T("_a"), NULL, NULL, &lookAt, ent) != RTNORM)
PS: don't forget, that all of needed elements MUST be visible on the screen. so, you need to "zoom all" before using acedSSGet
Message 6 of 8
jlobo2
Thanks Nick,
Appreciate your help.
Message 7 of 8
maisoui
in reply to: jlobo2
Another approach is to loop on entities in current space block table record. Are you really needed acedSSGet?
Here's a small example (for Model Space) :
Acad::ErrorStatus es;
//get model space block
AcDbBlockTableRecordPointer pBlockTableRecord(ACDB_MODEL_SPACE, m_pDatabase, AcDb::kForRead);
if((es = pBlockTableRecord.openStatus()) == Acad::eOk)
	//loop on each entities in model space
	AcDbBlockTableRecordIterator * pIterator = NULL;
	if((es = pBlockTableRecord->newIterator(pIterator)) == Acad::eOk)
		for(pIterator->start(); !pIterator->done(); pIterator->step())
			if((es = pIterator->getEntityId(entityId)) != Acad::eOk)
				continue;
		delete pIterator;
Jonathan
Message 8 of 8
jlobo2
Hey Jonathan,
Thanks for your reply.
While using acedSSGet(); I was having some difficulty to get the exact Entity Id, So I did go ahead and implement the Model Space approach instead of Selection Set.
Was just curious to know, if there was something missed while using acedssGet, since it would make things simple, as it would a single line code.
Appreciate your help Jonathan.
”Boost
