ObjectARX
downClose an object
8 REPLIES 8
Message 1 of 9
Moshe-A
509 Views, 8 Replies
downClose an object
Guys,
some where in the docs i saw there is a way to downClose an object if it is had multireaders
How?
thanX
moshe
8 REPLIES 8
Message 2 of 9
owenwengerd
in reply to: Moshe-A
It has nothing to do with multiple readers, but maybe you are thinking of downgradeOpen().
Owen Wengerd
ManuSoft
Message 3 of 9
Moshe-A
in reply to: owenwengerd
Owen hi,
No i thought about AcDbObject::isReallyClosing() but this does not solved the problem i encounter...
i have a dynamic block (inserted in ) with 3 Visibility options and i want to set it but always gets
eHadMultipleReaders error so i thought the AcDbBlockReference is opened more than one time
but with AcDbObject::isReallyClosing() it turns out it is open only one
here is the function i call to do that....BlkRefId is the block id that is open for read only once
openDirValue has the new value to set
bool setDynamicBlockPropertyValue(AcDbObjectId BlkRefId, AcDbEvalVariant openDirValue)
  AcDbDynBlockReferencePropertyArray DynBlkRefPropArray;
  DynBlkRefPropArray.setLogicalLength(0);
  AcDbDynBlockReference DynBlkRef(BlkRefId);
  DynBlkRef.getBlockProperties(DynBlkRefPropArray);
  AcDbDynBlockReferenceProperty DynBlockReferenceProp;
  for (inti = 0; i < DynBlkRefPropArray.length(); i++)
    DynBlockReferenceProp = DynBlkRefPropArray.at(i);
     if (DynBlockReferenceProp.propertyName() == _T("Visibility") &&
         DynBlockReferenceProp.propertyType() == AcDbEvalVariant::kString &&
         DynBlockReferenceProp.readOnly() ==  false&&
         DynBlockReferenceProp.show() ==  true)
        DynBlockReferenceProp.setValue(openDirValue); // set visibility returns eHadMultipleReaders
       return true;
  return false;
Moshe
Message 4 of 9
owenwengerd
Why did you leave the BlkRefId object open for read? Did you try closing it before calling setDynamicBlockPropertyValue()?
Owen Wengerd
ManuSoft
Message 5 of 9
Moshe-A
Owen
As always you got the sharp senses...you are the one of the bests.
thank you very much
moshe
Message 6 of 9
owenwengerd
Thank you. BTW, based on your usage of the function arguments, you should change the function signature like so:
bool setDynamicBlockPropertyValue(const AcDbObjectId& BlkRefId, const AcDbEvalVariant& openDirValue)
Owen Wengerd
ManuSoft
Message 7 of 9
Moshe-A
why? i do not set these arguments in getDynamicBlockPropertyValue() and do not need them in the caller
but i do have an issue with openDirValue...
here is what i do before calling setDynamicBlockPropertyValue()
AcDbEvalVariant openDirValue;
AcDbObjectId ObjId = pEnt->objectId();
pEnt->close();
getDynamicBlockPropertyValue(ObjId, openDirValue)
if (_tcsicmp(openDirValue.resval.rstring, _T("Left Openning")) == NULL)
  openDirValue = _T("Right Openning");
else
 if (_tcsicmp(openDirValue.resval.rstring, _T("Right Openning")) == NULL)
   openDirValue = _T("Left Openning");
setDynamicBlockPropertyValue(ObjId, openDirValue);
the compare with openDirValue string value fails because is contains a space.
how can i solve it?  (i prefer to keep the visibility options as the are)
moshe
Message 8 of 9
owenwengerd
The arguments should be const because you're not changing them, and by reference so you don't create and discard copies for no reason. I doubt that the space has any bearing on your string comparison. I think the misspelled word "Opening" is more likely the reason.
Owen Wengerd
ManuSoft
Message 9 of 9
Moshe-A
Ok i accept your rermark on const and by reference
regarding openDirValue, for a while instead of space i put there a dash and  it start to work
after a while it stops working although DynBlockReferenceProp.setValue(openDirValue) returns
Acad::eOk do not know why? or how? it was frustrating...
after you turned my attention for the misspelled 'openning' i also removed the dash and restored the space
there i discoved that there was and extra space in the visibility parameter (you can not see it by eye)
than i fix it it its now working Smiley Very Happy
again, thank you very much for your help, i turly appreciate it.
Moshe
”Boost
