ObjectARX
DBX Load Error
2 REPLIES 2
1131 Views, 2 Replies
DBX Load Error
Hello all,
Perhaps I am missing something simple somewhere. But can't figure out what.
I have a ObjectARX app that is working fine. I open AutoCAD, load DBX, then load ARX and it does what I want.
I needed to use some object from another DLL that is created by a colleague. So I added headers and code. Then I link to the lib in project settings. The compile and link of DBX goes smooth.
Then I copy the new DLL in the same folder where I have my DBX file and try to load the DBX in AutoCAD using Appload. The DBX load fails.
If I remove all the code of the new object, remove the linking, and build DBX, the DBX loads fine.
Looks like DBX is not loading because I added dependency on this new DLL. I opened the DBX file and new dll in dependency walker and they seem fine.
Any ideas?
Thanks in advance,
K
Tags (3)
2 REPLIES 2
owenwengerd
Unless your DBX folder is in the Windows search path, Windows won't find your DLL when AutoCAD loads your DBX. See my blog for a solution:
Using /delayload to specify dependent DLL path
Owen Wengerd
ManuSoft
in reply to: owenwengerd
Worked like a charm!!! Thanks a lot.
”Boost
