ObjectARX
DB Object deleting
4 REPLIES 4
leonimas
528 Views, 4 Replies
DB Object deleting
Hi to all,
I need to mask the normal delete command of a db entity; my problem is:
the user select a db object, press the "canc" key and my arx code resolves
the deleting action ...
If some constraints are true the code delete the object, otherwise not, the
erase command will not work.
Please, how can I solve this problem ? Reactors ? Which event (erased,
unappended, ... )
Best regards
Leonard
4 REPLIES 4
Anodl
in reply to: leonimas
Hi Leonard,
override AcDbObject::subErase (or use AcDbObjectOverrule::erase) to intercept the erase procedure and to prevent the object form being erased, if necessary.
Arnold
leonimas
in reply to: Anodl
Hi Arnold,
your solution is only valid to custom class derived from AcDbObject and/or
AcDbEntity ? If I use native class such as AcDbBlockReference or AcDbPolyLine ?
Many Thanks
Leonard
Anodl
Leonard, for native ARX classes or other third party classes use AcDbObjectOverrule::erase, for your own classes you can override AcDbObject::subErase. HTH Arnold
leonimas
in reply to: Anodl
Hi Anodl,
there is an example how to use the AcDbObjectOverrule class ? Must I derive
a my class from it ? where I have to instantiate the erase method (inside
ObjectARX EntryPoint class) ?
Many Thanks
Leonard
”Boost
