ObjectARX
Custom entity with annotation scaling feature
16 REPLIES 16
Message 1 of 17
maisoui
1691 Views, 16 Replies
I like to implement annotation scaling feature (like AcDbText, AcDbHatch, ...) in my custom entities. Does anyone have a solution?
Best regards
Jonathan
16 REPLIES 16
Message 2 of 17
StephenPreston
in reply to: maisoui
To achieve that we recommend you derive your cystom entity from an AutoCAD entity that already supports annotation scaling. Then you get it for free.
Cheers,
Stephen Preston
Autodesk Developer Network
Message 3 of 17
...There is a sample in the ObjectARX SDK called AnnotationScaling which has a custom entity defined. I wrote it, so please write to me if you have any questions.
Fenton Webb
Fenton Webb
AutoCAD Engineering
Message 4 of 17
maisoui
in reply to: fenton.webb
I use your sample to implement annotation scale protocol without deriving from a primitive annotative entity (like AcDbText). Here is what I did:
  • create a custom entity
  • create needed annotation objects deriving from AcDbAnnotativeObjectPE, AcDbObjectContextInterface
  • create a custom ScaleContextData deriving from AcDbObject (to store paper and drawing units)
  • add class protocol extension to my custom entity:
MyCustomEntityAnnotative::desc()->addX(AcDbAnnotativeObjectPE::desc(), new MyAnnotativePE);
MyCustomEntityAnnotative::desc()->addX(AcDbObjectContextInterface::desc(), new MyAnnotativeContextInterface);
  • create a custom context menu (deriving from AcEdUIContext) to reproduce AutoCAD 'Annotation Scale Object' context menu
So I only need to derive from my custom entity to have annotation scale protocol. It works but I encountered issues with AutoCAD commands:
  • AIOBJECTSCALE ADD/REMOVE don't seem to recognize my entity and don't edit it
  • OBJECTSCALE seems to deal with my entity but crash without displaying anything
I hope it can help someone. I always try to find a solution to this crash.
Regards.
Jonathan
Message 5 of 17
fenton.webb
You mention it works, yet you say it also has problems with AutoCAD commands - currently you cannot derive your own Annotative custom entity because not all of the API is public at this time, that's why it doesn't work. The solution is to derive from Annotative objects, as mentioned before.
Sorry for the bad news. If you are ADN member, ask to log a Change Request through the DevHelp online system.
Fenton Webb
Autodek Developer Network
Fenton Webb
AutoCAD Engineering
Message 6 of 17
subpartner
I am doing some tests by deriving from AcDbText (following your example), but it seems that methods 'subGetGripPoints' and 'subMoveGripPointsAt' don't work. I want to overload them... Is there a trick?
Best regards,
Jonathan
Message 7 of 17
fenton.webb
When you say it doesn't work, what do you mean?
Fenton Webb
Fenton Webb
AutoCAD Engineering
Message 8 of 17
subpartner
I found the solution. I need to implement the second version of 'subGetGripPoints' with following args: AcDbGripDataPtrArray & grips, const double curViewUnitSize, const int gripSize, const AcGeVector3d & curViewDir, const int bitflags. Then I return 'Acad::eNotImplementedYet' and it call the first version of subGetGripPoints.
My next question is about the specifi context menu for annotative entities (like AcDbText, AcDbHatch, ...), called 'Annotative Object Scale'. Do you know which is the condition used by AutoCAD to determine if this menu will be displayed? My workaround is to create my own AcEdUIContext (exact copy of Annotative Object Scale' one) and to add it to all my custom annotative entities (using acedAddObjectContextMenu).
Jonathan
Message 9 of 17
renencon
Is there a way to create scale dependent object properties for a custom annotative object (derived from AcDbText for example)
Tasos
Message 10 of 17
subpartner
in reply to: renencon
I'm sorry I didn't understand what your really want. Can you give an example?
Otherwise, I noticed another little thing. When a custom entity (inheriting AcDbText) is selected and the properties palette opened, I see that it is written Text in the selection combo box instead of the name of the custom entity. Anyone knows a way to fix that?
Best regards,
Jonathan
Message 11 of 17
owenwengerd
in reply to: subpartner
You can handle IOPMPropertyExtension::GetDisplayName() and return a custom name for DISPID 0x0401 (ObjectName property). This is the name AutoCAD displays in the properties window.
Owen Wengerd
ManuSoft
Owen Wengerd
ManuSoft
Message 12 of 17
subpartner
in reply to: owenwengerd
Thanks for your quick reply. I saw this article "Changing the Entity Type name that appears in the OPM window" on the ADN website talking about your solution. But it's necessary to implement COM wrapper and register and... It's a big process only to change the display name of an entity! Moreover, 2013 API OPM methods will change.
Is there an easier way?
Message 13 of 17
maisoui
Hi there,
Again a litlle thing about annotative custom object deriving AcDbText : Hatching. I cannot find which method I need to implement to make my custom entity dealing with hatching process. Unlike standard entities, method "subExplode" isn't called and hatch ignore my entity to determine its boudaries.
Anyboday have a solution?
Jonathan
Jonathan
Message 14 of 17
Fenton Webb
Really? I'm very interested in this - but I can see no sample like that in the kit? at least by name.... Can you help me with finding it?
Thanks!
Message 15 of 17
Alexander.Rivilis
This sample was in ObjectARX SDK 2008 and 2009. You can find and download ObjectARX SDK 2009 from this URL: http://download.autodesk.com/esd/objectarx/2009/ObjectARX_2009_Win_64_and_32Bit.exe
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 16 of 17
in reply to: Alexander.Rivilis
lol Thanks! I only checked back 3 years... 😉
Message 17 of 17
geez thanks again! some great stuff in there....
”Boost
