ObjectARX
Active Contributor
sdphg
Message 1 of 3 (242 Views)
custom entity inherit from AcDbPolyline can not display without app loaded
242 Views, 2 Replies
06-14-2012 12:14 AM
I have a custom entity inherit from AcDbPolyline,it works fine when the dbx and arx file load.but when you save the file and open it without load those two files,the proxy information dialog show and select show proxy option,the proxy entity didn't show.but when you use CTRL+A to select all,it said the proxy entity has been selected.If I choose to inherit from AcDbEntity,everything is ok.why?
thanks.
AcDbPolyline does not draw proxy graphics for derived classes, at least in earlier versions of AutoCAD. You can override the AcDbEntity::saveAs() method to draw proxy graphics for your object.
Distinguished Mentor
owenwengerd
Message 2 of 3 (233 Views)
Re: custom entity inherit from AcDbPolyline can not display without app loaded
06-14-2012 05:54 AM in reply to: sdphg
Owen Wengerd
ManuSoft
Active Contributor
sdphg
Message 3 of 3 (219 Views)
06-14-2012 11:21 PM in reply to: owenwengerd
thanks owen,that's the reason.
