ObjectARX
Custom Entity, help me
5 REPLIES 5
531 Views, 5 Replies
Sorry my english is not best!
I have a question. I want to generate a my custom entity class in ObjectDBX, which inherit AcDb Entity, either polyline or spline. That is, in the Autocad, with my Custom Entity class i can daw my custom polyline or spline. Please tell me how to do that?
5 REPLIES 5
Balaji_Ram
You may install ObjectARX Wizard and then use it to create this custom entity.
I have attached a screenshot outlining the steps to get you started.
Cheers,
Balaji
Developer Technical Services
Balaji
Autodesk Developer Network
in reply to: Balaji_Ram
thank you so much!!! I'm sorry, How to my custom entity class inherits both Polyline, Spline and Text
artc2
Custom objects/entities cannot inherit from multiple other classes in the ARX runtime tree. The reason is that the ARX runtime tree implementation cannot deal with multiple inheritance within the tree.
So, your custom entity can derive from AcDbPolyline, AcDbSpline, or AcDbText, but not all three (or even two) at the same time.
If you really need to the data and/or functionality of all three, then perhaps you could embed one of each of those three entity types within your custom entity and then implement methods on your custom entity that call through to the embedded entities' methods.
Embedding entities does require some special handling for dxf filing.  There is a section about this in the ObjectARX Developer's Guide.
Thank you for all reply so much! I'm a VietNamess, I'm learning ObjectARX, I hope to receive more help from you. Happy to be acquainted with all of you, my yahoo nickname's mcx_bkhn
Balaji_Ram
Hi !
Happy to know you too Smiley Happy
Good luck with your ObjectARX learning and feel free post your doubts in this forum.
Balaji
”Boost
