ObjectARX
Custom entity and hatching island detection problem
3 REPLIES 3
maisoui
396 Views, 3 Replies
I created a custom entity and implement the method subExplode to explode in 3 entities : a border polyline (closed), an inside polyline (closed) and an hatch inside the inline polyline.
A problem occured when I'm trying to create an hatch "excluding" my custom entity. There is no problem if I use the pick internal point mode, but if I use the select objects mode nothing happens when I select my custom entity. It seems that the hatch created in the subExplode method causes problem to the island detection, because if I don't create an hatch in the explode, everything works correctly.
Is there a way to have an explode context? Maybe I need to have a contextual subExplode method.
Any suggestions are welcomed. 🙂
Jonathan
3 REPLIES 3
Balaji_Ram
in reply to: maisoui
Hi Jonathan,
I could reproduce the behavior using a simple custom entity that I implemented.
I have contacted our engineering team on this and will get back to you.
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
Balaji_Ram
Sorry, it seems AutoCAD is not removing the hatch from the exploded entity set as it does with Block reference for example.
I have logged this in our internal database for our engineering team to analyze.
Balaji
Balaji
maisoui
in reply to: Balaji_Ram
Thank you for your reply. I hope a fix/workaround will be available soon.
Jonathan
”Boost
