ObjectARX
ObjectARX
New Member
rwfrenz20
Message 1 of 2 (193 Views)
Creating Index File from IAcPcDataBuffer
193 Views, 1 Replies
01-19-2012 06:28 AM
I'm having trouble finding the appropriate documentation for how to create an point cloud index file (PCG).  The only API function I have been able to locate is acpcIndexPointCloud which is a bit too high-level (i.e. it takes an input file name).
What I am trying to do is create a PCG from points in memory.  I have created a class which implements IAcPcDataBuffer and holds my data...could someone point me to the appropriate class/function(s) to use to save it to PCG?
Thanks in advance,
Ryan
ADN Support Specialist
fenton.webb
Message 2 of 2 (174 Views)
Re: Creating Index File from IAcPcDataBuffer
01-30-2012 03:40 PM in reply to: rwfrenz20
Sorry, but this is not possible I'm afraid. You may be able to write your points to a LAS file on disk and then call the indexer function that way. Creating the LAS file is a slight pain, so you could also consider writing an ascii file and then use a public domain program called Text2Las to generate the LAS file that way, and then index that...
Cheers
Fenton Webb
Autodesk Developer Network
Fenton Webb
Developer Technical Services
