ObjectARX
Create ToolBars in Autocad
2 REPLIES 2
711 Views, 2 Replies
Hi everyone! I have a custom entity. I have created a command "DRAW" to draw the custom entity but now i want to create a toolbar on Autocad. When botton of the toolbar is clicked, the command is excuted. I search to learn on google but don't understand. Please help me, thanks!
2 REPLIES 2
Alexander.Rivilis
There are few method of creating toolbar. It is a method of creating toolbar with ActiveX-model of AutoCAD: http://forums.autodesk.com/t5/Autodesk-ObjectARX/New-ToolBar-sample/m-p/1667385#M20461
Also you can look function CreateToolbars (file samples\entity\polysamp\polymnu.cpp within ObjectARX SDK).
Facebook | Twitter | LinkedIn
Expert Elite Member
StephenPreston
Or you can create a partial CUI to define your toolbars/ribbon elements.
Cheers,
Stephen Preston
Autodesk Developer Network
Cheers,
Stephen Preston
”Boost
