ObjectARX
copied-fkt of an entitiereactor does not react
2 REPLIES 2
_mm_
144 Views, 2 Replies
hello,
my entity has an entityreactor with the copied-function:
virtual void copied(const AcDbObject* dbObj,const AcDbObject* newObj);.
if i copy this object with the copy-button in acad it works unproblematic.
but the problem is, if i use strg+c to copy and strg+v to paste the new entity in the map, then the pasted entity has another id as the object (newObj) that is given in the copied-fkt of the reactor -> its not the same.
why? i want to copy information from the oldObj to the newObj, but its impossible with the usage of Strg+c and Strg+v.
have anyone an idea?
with kind regards
marco
2 REPLIES 2
in reply to: _mm_
This is as it should be.  The strg+c copies
the selected entities out to a temporary drawing file.  The strg+v inserts
the temporary drawing file into the current document.  So, it's a two
step process and you only have a reactor monitoring the first step.
hello,
my
virtual void
if i copy this
but the problem
why? i want to copy
with kind
regards
marco
_mm_
in reply to: _mm_
is this a bug of acad (objectarx)?
marco
”Boost
