Convert string to double problem _tstof
Message 1 of 17
Hi Friend,
I am convert string to double problem,
CString strValue=_T("2.4");
double dValue = _tstof(strValue);
Output is
Current Output
dValue result is 2.39999999
Expected Output
but I want dValue result is 2.4
With Regards,
Vijay
Replies (16)
Message 2 of 17
Alexander.Rivilis
Please read about floating (double) value precision: https://en.wikipedia.org/wiki/Double-precision_floating-point_format
It is OK if instead 2.4 you see 2.399999999999... because maximum precision of double value is 16 digit.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 17
Hi, Ok but I want dValue result is 2.4 Which data format is used... CString strValue=_T("2.4"); double dValue = _tstof(strValue); Result is 2.399999 Expect is 2.4 Regards, Vijay
Message 4 of 17
Alexander.Rivilis
It is look like you did not understood me or did not read about precision of double value and how double value stored in memory. Not all double value can be stored in memory (or register) exactly as you write as string.
Expert Elite Member
Message 5 of 17
Understood that ...
Which data format is used for replace this source.
With Regards,
Vijay
Message 6 of 17
Alexander.Rivilis
Sorry but I did not understood what you want. Perhaps someone else will understand you and can help you. Is this question has any relation to ObjectARX?
Expert Elite Member
Message 7 of 17
Alexander.Rivilis
  // - ArxProject4.TestDouble command (do not rename)
  static void ArxProject4TestDouble(void)
    CString strNewValue; strNewValue.Format(_T("%g"), dValue);
    acutPrintf(_T("\nstrNewValue=%s"), LPCTSTR(strNewValue));
Command: TESTDOUBLE
strNewValue=2.4
Expert Elite Member
Message 8 of 17
Output is
Current Output
Expected Output
Here dValue is double datatype
I want result in double
Expected :
dValue is 2.4
Value are store in double data type not string format.
Other then string which datatype is used?
Message 9 of 17
acutPrintf(_T("\ndValue =%f"), dValue );
Current Output
dValue = 2.399999..
Expect Output is
But I want 2.4
double dValue = _tstof(strValue); \\ Replace is _tstof, to get expect result?
Message 10 of 17
Alexander.Rivilis
http://www.binaryconvert.com/convert_double.html
Expert Elite Member
Message 11 of 17
Alexander.Rivilis
@Anonymous wrote:
Expect Output is
But I want 2.4
You'll never get the "expected result", since double value can never be exactly the same as 2.4000000000000000000000000
Nearest value, which can be in double format  is 2.39999999999999991118215802999E0
I clearly explained ???
Expert Elite Member
Message 12 of 17
Ok
i want to read the strValue value is 2.4.
2.4 value is store into any datatype for multiplication process.[Using _tstof this is problem]
which convert is possible?
current output:
Example:
double dValue = 2.399999999 * 2;
dValue = 4.8;
Want output
Example:
double dValue = 2.4 * 2;
dValue = 4.8;
Message 13 of 17
Alexander.Rivilis
It is look like I can not help you. Sorry.
Expert Elite Member
Message 14 of 17
Yes Correct!
I want 2.4
not 2.3999999
replies _tstof() ==> this function
Message 15 of 17
Alexander.Rivilis
@Anonymous wrote:
I want 2.4
not 2.3999999
There is no function which can you use instead of _tstof() because double value can not have exact value 2.4
Every function which convert string "2.4" to double will be return value 2.39999999999999991118215802999E0 as more possible nearest to 2.4
Expert Elite Member
Message 16 of 17
tbrammer
I salute you for your patience, Alexander.
@sn.vijayan: You can't always get what you want.
You can't put a horse into a matchbox.
You can't put 2.4 into a double.
Accept it as it is.
Thomas Brammer ● Software Developer ● imos AG ● LinkedIn ●
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
Message 17 of 17
Alexander.Rivilis
Smiley Happy I was always told that I have an iron patience. I am glad that you appreciated it.
Expert Elite Member
