Hello...
Title: Convert ads_name to VLA-Object from C++ARX?
I want a function convert "vlax_ename2vla_objectC"
The "vlax_ename2vla_objectC",will convert "ads_name" to "vla-object"
You replace the "????" with your source C++ARX.
I need only VisualC++ARX
I need one function ads_retVLA_object(rr);
The function "vlax_ename2vla_objectC" return value idem with llisp:
(type (vlax-ename->vla-object (car (entsel)))
Please help me...!
[source=vlisp]
(Defun vlax_ename2vla_objectL(arg1_as_RTENAME / rr)
(setq g (type arg1_as_RTENAME))
(setq rr (vlax-ename->vla_objectarg1_as_RTENAME )
rr)
[/source=vlisp]
[source=cpp]
int
/*FCN*/vlax_ename2vla_objectC()
struct resbuf *pArgs =acedGetArgs ();
if(!pArgs)
return acedRetNil();
if(pArgs->restype != RTENAME)
AcDbObjectId id;
if(acdbGetObjectId(id,pArgs->resval.rlname) != Acad::eOk)
ads_retVLA_object(VLA-OBJECT)
[/source=cpp]
[source=virtualC+lisp]
(Defun vlax_ename2vla_objectC2012(a008 / e rr g j)
/*c2s: rr=nil,
g=(listp(e)&&(e!=nil))?dfn_ent_dxf_01(e):a008,
e=(type(g)==quote(ENAME))?g:nil,
j= (type(a008) == quote(VLA_OBJECT));
if (e)
rr=vlax.ename->vla_object(e);
else
{ if (j) rr=a008;
else alert("a008errC");
rr)
[/source=virtuaC+lisp]
Have you tried using the "ObjectIdToObject" method in the IAcadDocument interface ?
This will provide you with a pointer to the COM Interface (Ex : IAcadCircle) for the ObjectId that you pass to it as parameter.
You can find it under <ObjectARX folder>\samples\com\AsdkMfcComSamp_dg\CAcadDocument.h.
Hope this helps.
Hi, Balaji!
But how can return this pointer from arx to lisp? IMHO it is impossible.
Facebook | Twitter | LinkedIn
Hi Alexander,
I am not sure if the developer wants to pass it over to Lisp, because in that case the "vlax-ename->vla-object" would get the vla-object.
I thought the developer wanted to get the COM object using an ObjectId using C++ alone and had provided the Lisp code as a demonstration of what he wanted to do.
Sorry, but I might be wrong in understanding the question.
Hi, Balaji!
diagodose2009 try to develop lisp to arx compiler/converter. It is understandable on the questions which he regularly gives on this forum. That is why hi try to emulate (vlax-ename->vla-object) lisp-function with ObjectARX code.
