Show only
Search instead for
Hi All I am having problems creating a COM wrapper for AutoCAD 2004 for my custom entities. I can do it correctly for 2000-2002, but for some reason the objects in 2004/.Net will not. The DllRegisterServer() function is returning an error code. I can't seem to find what I am doing wrong.
I am having the some problems with a COM wrapper
for OPM in AutoCAD 2004 also. I started with the AsdkOpmX source from
2000-2002. The problem I'm experiencing is not being able to get the
project to link. Would you be willing to discuss this outside or inside the
newsgroup?
Hi
The original of this message with attached file has been moved to
the Customer Files area at
news://discussion.autodesk.com/autodesk.autocad.customer-files or
http://discussion.autodesk.com/WebX?14@@.ee940b5. GIFs, JPGs, or
PNGs smaller than 200k only may now be posted in all discussion
groups. Please ZIP your files if zipping will make them smaller.
Zipping files (if it saves space) is a courtesy to those who
download the files.
See the newsgroup guidelines at
http://discussion.autodesk.com/webx?groundrules.
Anne Brown
Manager, Moderator
Autodesk Product Support discussion groups
Discussion Q&A: http://www.autodesk.com/discussion
Subject:
Re: COM wrapper for OPM in AutoCAD 2004
Date:
Fri, 9 May 2003 11:20:45 -0700
"Eric Howard"
Newsgroups:
autodesk.autocad.objectarx
Chad,
I finally got it compiled and working. It registers correctly
and displays properties, however I have only one problem. During
the OnSet Event I
am not able to use the SetEnums Method. This used to work in
2000 - 2002. Could you take a look at that?
Hi Eric, I got your project and I will look at it on the weekend. Unfortunatly, I promissed to take my children to see the new X2 X-men movie and it's a 4 hour round trip to the nearest theater, so it will be Sunday before I will have the opertunity to look it over thoroughly.
