ObjectARX
choosing method to getSection
2 REPLIES 2
509 Views, 2 Replies
I would like to get section objects of solid/surface by vertical plane , I found 2 groups of method which are (AcDb3dSolid::getSection and AcDbSurface::createSectionObjects) and AcDbSection::generateSectionGeometry.
They seem to do similar things.. pls advise how to choose, any performace issue or which suitable for which task?
Thanks in advance..
2 REPLIES 2
fenton.webb
Have you seen the SectionPlane sample in the ObjectARX 2009 SDK... It shows how to do what you want, I think.
Fenton Webb
AutoCAD Engineering
Previous versions of ObjectARX SDK
Facebook | Twitter | LinkedIn
Expert Elite Member
”Boost
