ObjectARX
change the xdata of an Entity
1 REPLY 1
215 Views, 1 Reply
I created a Blockreference that contains xdata. After this I want to change
the values of the of xdata without erasing the whole Blockreference. I did
not find a methode like RemoveXdata (in the opposite to setXData). If I use
setXData serveral times for the same Entity did it automatically overwrites
the old xdata ? The follwing sample code works, but Im not sure if it is a
legal way to exchange the Xdata ?
(code without any errorchecking)
acdbRegApp(szAppname);
xdata=acutBuildList(...........) // My First Data
acdbOpenObject(pObj,eId,AcDb::kForWrite);
pObj->setXData(xdata);
pObj->close();
acutRelRb(xdata);
xdata=acutBuildList(...........) // My Changed Data
pObj->close();
acutRelRb(xdata);
Thank you
Jörg
PS: Thanks Art Cooney for ansering my last question
1 REPLY 1
setXData() will replace any xdata with the same RegApp name as that in the
data being passed into it. So, what you are doing is fine (and is the only
way to do it). If you pass in a RegApp name with no data after it, then
that RegApp name and any data associated with it will be removed from the
object.
"Jörg Kühne" wrote in message
news:1303D6282BB2B6BE459C8908412E7AF4@in.WebX.maYIadrTaRb...
> Hello,
change
use
overwrites
> pObj->close();
> acutRelRb(xdata);
> pObj->close();
> acutRelRb(xdata);
> Thank you
> Jörg
”Boost
