ObjectARX
can arx's be created in C# or VB.Net ?
5 REPLIES 5
341 Views, 5 Replies
Can .arx file be created in VB or C#?
Andy
5 REPLIES 5
No.
Cheers,
Stephen Preston
Developer Technical Services
http://adn.autodesk.com
"Andy Elmore" wrote in message
news:f182ce9.-1@WebX.maYIadrTaRb...
> Andy
I guess it depends exactly what you mean by "creating an ARX in VB or C#",
can you create an ARX w/o C++? No.
However, using the /CLR flag you get unmanged C++ (i.e., it compiles to
MSIL) which can then easily call into C# or VB; this is called IJW (It Just
Works). Another technique would be to expose your C#/VB code as a COM
object and use it like any other COM object from legacy C++.
Note that I haven't actually tired either method out with a real ARX.
Dan
"Stephen Preston" wrote in message
news:1F8A903072DECA8C5A913273931380DB@in.WebX.maYIadrTaRb...
> No.
> Cheers,
> Stephen Preston
> Autodesk
> > Andy
"J. Daniel Smith" schrieb im Newsbeitrag
news:8D93B6C0CD53B2FA174324EDD321E23A@in.WebX.maYIadrTaRb...
Just
> Works).
.NET assembly DLLs are different from native DLLs as they are compiled to
MSIL. They can't be loaded by AutoCAD
This works pefect and is pretty simple from C# or VB.NET.
> Dan
> > No.
> > Cheers,
> > Stephen Preston
> > Autodesk
> > > Andy
Just an hour ago, I got the first technique working; I even registered a
command that calls directly into C#.
The way I did it was to create small reusable stub "loader" ARX written in
C++ and compiled with the /clr flag which exports acrxEntryPoint(). The
filename of this ARX indicates the managed ARX to load: ARX/LOAD
_managed_acrxEntryPoint_ManagedARX.arx will load ManagedARX.dll. Since this
load stub can load a different managed ARX by changing its name, a managed
ARX developer would never have to see C++.
While this isn't anywhere close to being ready for prime-time, it does seem
to indicate that the basic idea could be made to work. Of course, this does
nothing for things like custom objects or the full C++ API.
Dan
"Andreas Mueller" wrote in message
news:9CA246E30D42A155F6D99230D5BDFA29@in.WebX.maYIadrTaRb...
C#",
> Just
> > Works).
> > Dan
> > > No.
> > > Cheers,
> > > Stephen Preston
> > > Autodesk
> > > > Andy
could you post your example. I would like to see how this is done.
Andy
"J. Daniel Smith" wrote in message
news:176C3248A88928582168121C34186227@in.WebX.maYIadrTaRb...
this
seem
does
> Dan
> C#",
to
> > Just
> > > Works).
to
> > > Dan
> > > > No.
> > > > Cheers,
> > > > Stephen Preston
> > > > Autodesk
> > > > > Andy
”Boost
