ObjectARX
761 Views, 6 Replies
^C^C
How to emulate well known in AutoCAD "^C^C" statement, you know to cancel
the current command prompt, with ObjectARX?
6 REPLIES 6
Try sending two ESC's to the command line, like:
acedGetAcadTextCmdLine()->SendMessage(WM_CHAR, VK_ESCAPE, 0);
There might be a better way than that now, but that is how we used to do
it...
Jim Awe
"HokuS" wrote in message
news:4885775@discussion.autodesk.com...
You can also use:
extern int acedPostCommand(char const *)
like this:
acedPostCommand("\03\03");
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
"HokuS" wrote in message news:4885775@discussion.autodesk.com...
I don't think acedPostCommand() is available in ObjectArx 2006. You can try using:
acDocManagerPtr()->sendStringToExecute(acDocManagerPtr()->curDocument(), "\x1B\x1B");
But remember that AutoCAD might not executed it when you want it to...
It certainly is.
Were it not available, I would have a few broken
apps that would not work at all.
Huh.
Sorry to continue this discussion in this thread, but I don't know how else to contact Tony (your website has a contact link, but it doesn't lead to any contact info).
I can't find any reference to acedPostCommand() in the ObjectArx online reference (index/search) or the index of the hardcopy ObjectArx Developer's Guide (both for AutoCAD 2006). Is it supported/deprecated but not documented? Something else?
thanks, Chuck
Hi, chuck.han!
This function is not documented and is not supported, but working in AutoCAD R14...2006 .
It exported by acad.exe and is in acad.lib You need add this statement your's code:
extern int acedPostCommand(char const *cmd);
After then you can use acedPostCommand("\03\03") for canceling any active command;
ch> I can't find any reference to acedPostCommand() in the ObjectArx online
ch> reference (index/search) or the index of the hardcopy ObjectArx
ch> Developer's Guide (both for AutoCAD 2006). Is it supported/deprecated
ch> but not documented? Something else?
Best Regards,
Alexander Rivilis.
”Boost
