ObjectARX
ObjectARX
mihajlovic.milosh
Message 1 of 6 (558 Views)
Block attributes auto-update
558 Views, 5 Replies
11-28-2011 02:53 AM
I want to do the following: import a block reference with attributes among which there are those that should contain the current coordinates of an entity from that block, and when I move that block those attributes should be updated in order to keep showing the current coordinates, the same way the dimensions are showing actual measurements even when resized.
I've tried to do this with fields in the attributes. But fields are not updated automatically on i.e. move command and I read that it could be time consuming for larger drawings.
So, the question is, how do I do this without developing custom entities?
EDIT: I forgot to mention that I'm doing this in Visual C++ 2005 with ObjectARX for AutoCAD 2008.
Moderator
Alexander.Rivilis
Message 2 of 6 (538 Views)
Re: Block attributes auto-update
12-01-2011 01:34 PM in reply to: mihajlovic.milosh
Maybe reactors?
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
mihajlovic.milosh
Message 3 of 6 (534 Views)
12-01-2011 01:46 PM in reply to: mihajlovic.milosh
Could you recommend me something where I can read how to implemet reactors?
Moderator
Alexander.Rivilis
Message 4 of 6 (533 Views)
12-01-2011 01:52 PM in reply to: mihajlovic.milosh
ObjectARX Developer's Guide -> Advanced Topics -> Notification -> Using Reactors
Valued Contributor
stuartnathan
Message 5 of 6 (495 Views)
12-16-2011 09:29 AM in reply to: mihajlovic.milosh
Not quite what you want, but I think may help.
Add a handler to the ObjectModified Event thus:-
      CurDb = Application.DocumentManager.MdiActiveDocument.Database
      AddHandler CurDb.ObjectModified, AddressOf ObjectModified
 and add this event.
   Friend Sub ObjectModified(ByVal sender As Object, ByVal e As Autodesk.AutoCAD.DatabaseServices.ObjectEventArgs)
      If isMod Then Exit Sub
      Dim b As Boolean
      With e.DBObject
         If .IsWriteEnabled Then Exit Sub
         If .Id.ObjectClass.Name = "AcDbAttribute" Then
            Using tr As Transaction = CurDb.TransactionManager.StartTransaction()
               Dim ar As AttributeReference = CType(e.DBObject, AttributeReference)
               With a_Job
                  ar.UpgradeOpen()
' add you code here and if you make an amendment, set b=True
                 If b Then isMod = True : ar.DowngradeOpen() ' isMod prevents loop
               End With
               tr.Commit()
            End Using
         End If
      End With
      isMod = False
   End Sub
 Your code will update tags where needed
Valued Contributor
stuartnathan
Message 6 of 6 (494 Views)
12-16-2011 09:31 AM in reply to: stuartnathan
ps.
You may need to trap the block object instead.
