ObjectARX
background color: acedSetCurrentColors() doesn't work for 3D visual styles
2 REPLIES 2
tbrammer
1238 Views, 2 Replies
Hi all,
I'm using acedSetCurrentColors() to change AutoCADs background color like that:
DWORD rgb=RGB(255,255,255);
AcColorSettings colors;
acedGetCurrentColors(&colors);
colors.dwGfxModelBkColor	= rgb;
colors.dwParallelBkColor	= rgb;
colors.dwGfxLayoutBkColor	= rgb;
BOOL bStat = acedSetCurrentColors(&colors);
This works well for the paperspace background and for the visual style "2D wireframe" (dwGfxModelBkColor).
But it fails for 3D visual styles like "realistic", "hidden" and so on (dwParallelBkColor).
If I call acedSetCurrentColors()  before any 3D-viewport exists and than switch to "realistic" - than the "realistic" view will have "my" backgroundcolor.
But as soon as a 3D-viewport exists it just keeps its background-color.
If I look at the background color using the UI (preferences->Drawing->Colors->3D-parallel projection) the dialog shows "my" color! But it's not updated in the view.
Any ideas?
I want to create images with PNGOUT, JPGOUT or BMPOUT with a special background color (usually white).
Does anyone know a way to create PNG, JPG and BMP with "my" backgroundcolor just like the commands would do?
This would help me out as well.
I also tried:
Using COM - no success:
CWinApp *pApp = acedGetAcadWinApp();
IAcadApplication *pIAcad = (IAcadApplication*)pApp->GetIDispatch(TRUE);
IAcadPreferences *pIAcadPreferences=NULL;
pIAcad->get_Preferences(&pIAcadPreferences);
IAcadPreferencesDisplay *pIAcadPreferencesDisplay=NULL;
pIAcadPreferences->get_Display(&pIAcadPreferencesDisplay);
OLE_COLOR oleColorNew = RGB(255,255,255);
pIAcadPreferencesDisplay->put_GraphicsWinLayoutBackgrndColor(oleColorNew);
pIAcadPreferencesDisplay->put_GraphicsWinModelBackgrndColor(oleColorNew);
Using some AcGs* stuff:
void update3dViewports(DWORD rgb)
	AcAxDocLock myLock;
	AcGsManager *pGsManager = acgsGetGsManager(NULL); //Manager for current MDI window
	AcGsModel *pGsModel = pGsManager->getDBModel();
	if (pGsModel)
		pGsModel->onPaletteModified();
	struct resbuf *pRs=NULL, *r=NULL;
	AcGsView *pView=NULL;
	int nCVPort=0;
	bool bDevice=false;
	if (acedVports(&pRs) != RTNORM)
		return;
	for (r=pRs->rbnext; r; r=r->rbnext)
		for (; r && r->restype!=RTSHORT; r=r->rbnext)
		if (!r)
			break;
		nCVPort = r->resval.rint;
		if (pView = acgsGetGsView(nCVPort, false))
			AcGsDevice *pDevice = pView->getDevice();
			if (pDevice)
				AcGsColor color;
				color.m_red   = GetRValue(rgb);
				color.m_green = GetGValue(rgb);
				color.m_blue  = GetBValue(rgb);
				bDevice = pDevice->setBackgroundColor(color);
			pView->invalidate();	// mark the AcGsView as invalid so that it knows it has to update
			pView->update();		// update the view
	acutRelRb(pRs);
Please help!
--Thomas
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
2 REPLIES 2
moogalm
in reply to: tbrammer
Hi ,
You need to call acedColorSettingsChanged to take changes effective , and sorry this is not an public API , I will request a wishlist with our Engineering to make this API public and provide neccessary documentation.
extern BOOL acedColorSettingsChanged(BOOL bUpdateView,
BOOL bUpdateParallelBg,
BOOL
bUpdatePerspectiveBg);
static void ASDkMyGroupBGColorTest(void)
    // Add your code for command asdkArxProject.Test here
    AcColorSettings pColorSettings;
    acedGetCurrentColors(&pColorSettings); // Get the current colors
    pColorSettings.dwGfxModelBkColor=RGB(255,0,0);// Set the background to red
    pColorSettings.dwModelCrossHairColor=RGB(255,255,0);// set the cursor to yellow
	pColorSettings.dwParallelBkColor = RGB(255,0,0);// set the 3dParallel projection to red
    acedSetCurrentColors(&pColorSettings);
	acedColorSettingsChanged(false, true, true);  // apply the changes. //...
tbrammer
in reply to: moogalm
Yep. This is it. Thanks!
”Boost
