ObjectARX
Distinguished Mentor
Moshe-A
Message 1 of 10 (184 Views)
attributes are placed in 0,0 position
184 Views, 9 Replies
11-07-2012 10:28 PM
Hi Guys,
In my application i have three block symbols contains some attributes. the current task i'm working on
is converting an old version of these blocks (the new version also are dynamic blocks)
let's say i have a host database that has a xref in and the xref contains the old blocks.
i scan the current database (AcDbBlockTableRecord) for that xref, open it and scan the xref database (AcDbBlockTableRecord) for those blocks it turn i find each block make an update insert (insert= from outside database) and replace each AcDbBlockReference. this all process work fine except the attributes at first are places
on the 0,0 position. after audit the xref and regen it, the attributes are restores in place were they should be.
would like to mention that i did not encounter this problem when i insert the blocks in the current database
or even replacing the symbols inside a standard block.
Any one knows what is my problem?
thanks in advance
moshe
Hallelujah!
it's working fine
thank you very much owen
i'm sure you have explanation to this and i understand it's related to display and graphics
but why does this happends only to attributes?
Moshe
Moshe-A
Message 2 of 10 (176 Views)
Re: attributes are placed in 0,0 position
11-08-2012 04:10 AM in reply to: Moshe-A
foregot to mention that audit results no errors
owenwengerd
Message 3 of 10 (170 Views)
11-08-2012 07:20 AM in reply to: Moshe-A
Have you tried setting the database current before adding the attributes?
Owen Wengerd
ManuSoft
Moshe-A
Message 4 of 10 (165 Views)
11-08-2012 10:27 AM in reply to: owenwengerd
Hi Owen,
NO
What do you mean by that? to set the Xref database current?
can i do that without closing the host database?
thanx
Moshe
owenwengerd
Message 5 of 10 (158 Views)
11-08-2012 06:32 PM in reply to: Moshe-A
Yes, and yes.
Owen Wengerd
ManuSoft
Moshe-A
Message 6 of 10 (151 Views)
11-09-2012 12:34 AM in reply to: owenwengerd
tried it and it still doesn't work, hope i use it good (cause i have never used AcApDocumentManager)
here's what i did
ACHAR XrefFile[32= = _T("xref.dwg");
AcDbDatabase *pXref = NULL;
// allocating memory
pXref = new AcDbDatabase(Adesk::kFalse);
pXref->readDwgFile(XrefFile);		{
// switch databases
acDocManager->setCurDocument(acDocManager->document(pXref));
replace_old_symbols(pXref); // real work
// restore current database
acDocManager->setCurDocument(acDocManager->document(pCurDwg));
pXref->saveAs(XrefFile);
delete pXref; // dispose memory
i would like to understand why is this happends - do you have explanation?
Moshe
Moshe-A
Message 7 of 10 (147 Views)
11-09-2012 02:19 AM in reply to: Moshe-A
Owen,
here's a simple test is did:
i draw a rectangle on the current database (with RECTANGLE command)
disable the call to restore the current database
// acDocManager->setCurDocument(acDocManager->document(pCurDwg));
then build & load & run my application again
then i tried to select the rectangle and i did successed
i thought if the xref database is current i won't be able to select objects in pCurDwg
is this means that the call
is not acutally done?
owenwengerd
Message 8 of 10 (140 Views)
11-09-2012 07:27 AM in reply to: Moshe-A
Try instead AcDbHostApplicationServices::setWorkingDatabase().
Owen Wengerd
ManuSoft
Moshe-A
Message 9 of 10 (137 Views)
11-09-2012 07:49 AM in reply to: owenwengerd
Hallelujah!
it's working fine
Moshe
owenwengerd
Message 10 of 10 (131 Views)
11-09-2012 08:54 AM in reply to: Moshe-A
I can only speculate that calculating text position after an alignment change requires information from the working database, and that the process is intentionally skipped or fails for some reason when the working database is different from the database of the target text object.
Owen Wengerd
ManuSoft
