Recently i migrated my project from vs2008 to vs2010, also from object arx 2010 to object arx 2013.
The output arx file works fine with AutoCAD Map 3d 2013, but when trying to load in Map 3D 2014, i get the following error.
*************************************** Error receive ******************************************************
c:\program files\Test\validation2013.arx cannot find a dll or other file that it needs.
AcRxDynamicLinker failed to load 'c:\program files\Test\validation2013.arx'
C:\Program Files\Autodesk\Autodesk AutoCAD Map 3D 2014\acad.exeUnable to load validation2013.arx file
Thanks in advance
with regards,
Chockalingam
Solved by owenwengerd. Go to Solution.
Solved by chockalingam. Go to Solution.
Hi all,
I found the answer.
Once i added the arx path in "Support File Search Path", the problem solved.
R.Chockalingam
It sounds like your ARX module has an implicit dependency on another DLL in the same folder as the ARX. Adding the ARX folder to AutoCAD's support path is a global solution for a local problem, and adds needlessly to the clutter in the user's AutoCAD settings. I recommend to fix your ARX instead.
Hi Owen Wengerd,
Thanks for your suggestions, i will definitely fix the my ARX
Chockalingam
