ObjectARX
append 3dObject ?
1 REPLY 1
211 Views, 1 Reply
append 3dObject ?
I want an example that when i draw 3d objects .I can use mouse to append to each other.
For example:
I draw two pipes , i want to append it into one pipe by mouse.How can i do it?
1 REPLY 1
fenton.webb
I don't have any samples for doing that specifically.
I have attached a .NET sample (sorry that's all I have) project showing how to create Solids, then Union, subtract or intersect - you should be able to create your application by following the code in this and applying it to ObjectARX (which is very similar)...
I hope it helps
Fenton Webb
Autodesk Developer Network
Fenton Webb
AutoCAD Engineering
”Boost
