ObjectARX
any way to remove password from a dwg
8 REPLIES 8
Message 1 of 9
421232206
6020 Views, 8 Replies
I want to remove password from dwgs whose password is know.  I can open these dwgs by known pasword, but I can't find a way to save them without password.
        SecurityParams secParams;
            secParams.cbSize = 48;
            secParams.ulFlags = 1;
            secParams.ulProvType = 1;
            secParams.ulAlgId = 26625;
            secParams.ulKeyLength = 40;
            secParams.wszPassword = szPassword;//if I give NULL to this param, the "saveAs" method crushes.
            secParams.wszProvName = _T("Microsoft Base Cryptographic Provider v1.0");
     es = pDb->saveAs(szFileName,&secParams);// I want to remove their passsword
Technology change world! Coding change technology! We coders are coding!
8 REPLIES 8
Message 2 of 9
owenwengerd
in reply to: 421232206
Pass NULL for the second argument to saveAs().
Owen Wengerd
ManuSoft
Message 3 of 9
421232206
in reply to: owenwengerd
thanks, but are you sure? I tried the following code,  it dosen't work. The password of the dwg still exists.
             AcDbDatabase* pDb = new AcDbDatabase(false);
            Acad::ErrorStatus es = pDb->readDwgFile(iterS->c_str(),_SH_DENYWR,false,szOldPassword);
            if (Acad::eOk == es)
                if (_tcscmp(szPassword,_T("")) == 0)
                    es = pDb->saveAs(iterS->c_str(),NULL);
                else
                    es = pDb->saveAs(iterS->c_str(),&secParams);
                if (Acad::eOk == es ) ++nCount;
Message 4 of 9
Try:
secParams.wszPassword =_T("");
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 5 of 9
CAD enters dead loop, If I pass an empty string(not null) .
Message 6 of 9
What about save dwg with other filename without password?
There is a method AcDbDatabase::setSecurityParams. Try pass NULL to it.
Expert Elite Member
Message 7 of 9
I tried, "save as" with a new file name, but the new dwg still has the same password from the old dwg.
Message 8 of 9
OK. Working code:
static bool RemovePasswordProtection(AcDbDatabase *pDb)
    const SecurityParams *parSecOld = pDb->cloneSecurityParams();
    SecurityParams parSecNew = *parSecOld;
    parSecNew.ulFlags = 0; // Clear all security flags
    return (pDb->setSecurityParams(&parSecNew));
// Main function remove password from current drawing
static void PWDRemovePwd(void)
    AcDbDatabase *pCurDb  = acdbCurDwg();
    AcApDocument *pCurDoc = curDoc();
    RemovePasswordProtection(pCurDb);
    pCurDb->saveAs(pCurDoc->fileName(),NULL);
Expert Elite Member
Message 9 of 9
thanks so much. It did work.  I noticed that cad  automatically remembers password , but found no way to remove this mechanism.
”Boost
